huntingbane Posted March 29, 2012 Share Posted March 29, 2012 im just asking if these colours would look good on my marine ok i hope you like it. they are: calthan brown for the base of everything then chaos black for the trim and knee pads last we have chain mail for the rims of the exhausts on the pack. also the eyes, mouth and the pipes also in chainmail. I have done a pic on space marine painter but cant get it up. so i hope you like the paint scheme. Link to comment https://bolterandchainsword.com/topic/249835-would-these-colours-be-good-for-my-space-marines/ Share on other sites More sharing options...
Myxx Posted March 29, 2012 Share Posted March 29, 2012 definitely need to see either a digital mock-up or a real test model before casting judgement... Link to comment https://bolterandchainsword.com/topic/249835-would-these-colours-be-good-for-my-space-marines/#findComment-3027239 Share on other sites More sharing options...
Brother Tyler Posted March 29, 2012 Share Posted March 29, 2012 Okay, based on your description and using the hexadecimal codes found here (that's the Librarium article, but the codes are actually given here), I get something like the image at right (SMP version 9) or left (SMP version 5).[clearfloat][/clearfloat]That may not be exactly what you envision, so here's how you can post your image. When the image pops up in the next screen, don't copy the URL from the top. Instead, right click on the image and copy the image URL (depending on your browser, you might view the image properties and copy that, or, using Firefox, simply select "copy the image URL"). If you're using SMP ver 5, once you complete the image click "Finalize" at the center bottom. At the next screen click "URL for image." Then past that image between the image BBCode. In the case of the image I've shown, you get:[img=http://www.bolterandchainsword.com/sm/bpe=8E8C91&bpj=8E8C91&bp=7A4231&bpc=7A4231&hdt=7A4231&hdm=7A4231&hdl=7A4231&ey=8E8C91&er=7A4231&pi=8E8C91&nk=7A4231&ch=7A4231&eg=7A4231&sk=7A4231&abs=7A4231&bt=7A4231&cod=7A4231&ull=7A4231&lk=001522&lll=7A4231&lft=7A4231&url=7A4231&rk=001522&lrl=7A4231&rft=7A4231&slt=001522&sli=7A4231&srt=001522&sri=7A4231&ula=7A4231&lel=7A4231&lla=7A4231&lw=7A4231&lh=7A4231&ura=7A4231&rel=7A4231&rla=7A4231&rw=7A4231&rh=7A4231&bg=FFFFFF&rb=7A4231&gr=8E8C91&/spacemarine.jpg][/imageleft][imageright][img=http://www.bolterandchainsword.com/sm.php?b62c=@hzyb7_hF86R.h1Xd8__@@@@@_@_@@@@@@@@.@@@.@@.@.@@@@@@@@@@@_@@@@@@@@@@@__@_iakk7&] For SMP ver 5 you have to manually type in the image BBCode. Note that I've used the imageleft tags to position the SMP ver 5 image on the left side of the post.If you're using SMP ver 9, once you complete the image simply click on the "Use the Image on the B&C" button on the right side and cut and paste the code & URL into your post. In the case of the image I've shown, you get: [img=http://www.bolterandchainsword.com/sm.php?b62c=@hzyb7_hF86R.h1Xd8__@@@@@_@_@@@@@@@@.@@@.@@.@.@@@@@@@@@@@_@@@@@@@@@@@__@_iakk7&] For SMP ver 9 the image BBCode is automatically entered when you paste the URL into your post. Note that I've used the imageright tags to position the SMP ver 9 image on the right side of the post. Link to comment https://bolterandchainsword.com/topic/249835-would-these-colours-be-good-for-my-space-marines/#findComment-3027258 Share on other sites More sharing options...
Razblood Posted March 29, 2012 Share Posted March 29, 2012 I'd make the eyes a different colour such as Green or Yellow that would really make them pop. Link to comment https://bolterandchainsword.com/topic/249835-would-these-colours-be-good-for-my-space-marines/#findComment-3027291 Share on other sites More sharing options...
