Wolf Guard
Hey guys,
Ive just brought some wolf guard terminaters and i wanted to make a deathstar type unit rather then using them as upgrades for grey hunter squads
I mostly play, TAU, imperial guard, Eldar and necrons
I'm trying to work them around a 2000 point scheme, and after reading the book and looking at the sprues they come with im really really unsure on what to make them with
Do i give 2 SS and thunderhammers? or all of them Wolf claws?? or even powerfists... i just really really dont know.
i know theres a thread very similar but the answers arnt there that im looking for. Im not really a massive fan of Combi weapons and i will be drop podding these units asap
And one last question rather then creating another post, whats the most effective way to pain a blueish colour for space wolves rather then more greysish
Thanks for any help!
https://bolterandchainsword.com/topic/249869-wolf-guard/
Considering your post, and the questions contained therein, there's some points that need to be stated:
- TH/SS is considered the better weapons pair when hunting things at higher Init, such as the Eldar and it will screw with the Necrons.
- Paired WC's are what I use; however, at times, I find myself wanting that 3+ Invi
WC/SS could prove interesting, just without having a High Str weapon, there's really nothing to do against MC's or higher Toughness models.
How many can you make, what's transporting them (if anything)? If five, maybe give them:
- WG TDA w/ WCx2
- WG TDA w/ WC/SS
- WG TDA w/ TH/SS
- WG TDA w/ PF (of CF)/AC
- WG TDA w/ PW/SB (or SS)
This or other custom builds increase the chances of taking saves on only one model, but it does mean bleed over of saves may result in the loss of valuable weapons setups.
https://bolterandchainsword.com/topic/249869-wolf-guard/#findComment-3028391
Another variation is the SS & CF. For when you really need to take out armour.
I've often wondered about combos like SS & CML to go with a LF pack.
I use the last one a lot but i give it mark of the wulfen to, makes for a good all rounder.
I always thought that giving a Wolf guard a storm shield AND a thunder hammer was counter productive. If you put them on other models you can always allocate away from it.
SS + either AC/CM or Frost blade or WC. TH + Combi weapons or WC (incase you need to make some initiative attacks instead).
https://bolterandchainsword.com/topic/249869-wolf-guard/#findComment-3028600
The way ive ended up making them is...
2 with thunder hammer and storm shield
1 with power fist and assault cannon
1 with 2 wolf claws
1 with power weapon and storm bolter
Logic is that I can have the unit in a drop pod and upon impact I can shoot down and wither any immediate threat with the assault cannon and storm bolter. I then have my wolf claw and power weapon striking at initiative order to again try and avoid too many loses whilst wound allocation goes on the 2 storm shields. I also then have a very capable anti tank unit.
1 question. If I PAIR wolf claws can I re roll both to hit and wound?? As I have 2. And would I be best swapping the power weapon for a wolf claw??
https://bolterandchainsword.com/topic/249869-wolf-guard/#findComment-3028973
For 5 points you are getting a re-rolling PW, so I almost always take them over a normal PW. But, it's also nice to have a body or two that you don't sink any points into for 'dorks', or 'chumps', or whatever you call them. The first to die.
You are also missing the cheap combi weapons that our TDAWG can hold. These don't come in the kit, but are work taking, even in a CC centric pack. Podding down and blowing up a transport so that you can hack it all up next turn is great fun, and has never disappointed me (except when I miss with my combi weapons...).
For a close combat pack I take:
TDA/PF/AC
TDA/SS/WC
TDA/SS/TH
TDA/CM/WC
TDA/CM/WC
Drop Pod
End of Line
https://bolterandchainsword.com/topic/249869-wolf-guard/#findComment-3029109
As i said im quite against combi weapons, if you've ever seen me play i seem to roll alot of misses.... alot.... i know combi weps would be wasted
what is the beneficial point to taking 2 wolf claws?, i kinda wanted to emphasise close combat in this unit, i play against guard and tau alot. so i really dont want to be in the open alot. The assualt cannon was really just an added to finish of little units and i was really against taking one to be honest.
What does TDA mean?, sorry im new to all these abbreviations. the
https://bolterandchainsword.com/topic/249869-wolf-guard/#findComment-3029177
Ok, i will take your advice into account, but i thought thunder hammers are good vs Tanks? and TDA?..
They do ok, however instead of str 8+1d6 that your TH gets, your CF get the 2d6 bonus against mech. Let's say your in CC with a dread type; your TH needs to roll to hit as well as rolling a 4+ just to glance and 5+ to pen on one die, while your CF gets two dice. The nice thing about TH is it will stun a Dread up any hit which will reduce it's attack profile by 1. So they are great in conjunction with each other.
https://bolterandchainsword.com/topic/249869-wolf-guard/#findComment-3029208
So the way to alter my terminators would to be
1 With storm Shield and Chainfist...( more resiliant, good anti-tank/ high toughness )
1 with Stormshield and thunderhammer...( "")
1 with assault cannon and powerfist...( more diversity and range )
2 with 2 wolf claws ( strikes in Initiative order and dealing with medium targets )
Is there any way this unit could be improved? The unit will be deepstriked turn 1 into the thick of it. maybe either hold up a couple of units or deal with some armoured targets and elite units
https://bolterandchainsword.com/topic/249869-wolf-guard/#findComment-3029275
https://bolterandchainsword.com/topic/249869-wolf-guard/#findComment-3029276
TDA or Tactical Dreadnought Armor=Terminator Armor
I scanned over where you mentioned your distaste of combi weapons, sorry.
CF, or Chain Fists are better against tanks because of the 2d6 for wounding/damage/whatever against vehicles. Thunderhammers are great for smacking high initiative units or models because it takes their I down to 1.
End of Line
https://bolterandchainsword.com/topic/249869-wolf-guard/#findComment-3029277
Ok, so....
For maximum benefit and value for points as a squad do you guys think this setup works?
2 wolf guard with wolf claws, 1 with melta bombs
1 with assault cannon and power fist
1 with thunder hammer and storm shield
1 with chain fist and storm shield
All used in a first turn drop pod, capable of withstanding enemy fire and equally threatening to armoured enemies and elite units.
Can anyone else think of any changes that would fulfill this role any better or make any changes in general, would this unit be too much of a point sink?
https://bolterandchainsword.com/topic/249869-wolf-guard/#findComment-3029417
1 with assault cannon and power weapon
Yeah your good,
Something to consider. The power fist on the assault cannon maybe overkill, you could just put a power-weapon on him and call it a frost blade if/when you want an upgrade for that piece. So an Assault Cannon / PW or FB and another option for the piece would be MB for the extra hit against tanks.
I just hate seeing a piece go over 63 points for a 1 wound model.
https://bolterandchainsword.com/topic/249869-wolf-guard/#findComment-3029486
I saw nobody adressed the colour question, so I will see what I can do..
Space Wolves Grey (which I like to use) is a (baby) blueish colour, along with the darker Shadow Grey and most dark Fenris Grey.
https://bolterandchainsword.com/topic/249869-wolf-guard/#findComment-3029763
Yeah your good,
Yea, this was going to be my last suggestion. When I have the points, my CML WGTDA get frost blades. With the above suggestion, you have at least 3 models going at initiative with power weapons, two with rerolling hits or wounds and one possibly laying the smackdown at strength 6.
https://bolterandchainsword.com/topic/249869-wolf-guard/#findComment-3029897
I have had good luck with the five I have kitted out as follows...
1 x storm bolter/chainfist
1 x stormbolter/powerfist
1 x stormbolter/frostblade
1 x stormbolter/wolfclaw
1 x stormbolter/thunderhammer
I just can't bring myself to leave them without being able to shot. So far it has worked out well for me. But they have to use cover if they are footslogging across the table. You just have to keep them moving. That and having Logan and Bran with them helps. My wolves rarely stay put for very long regaurdless of the mission.
https://bolterandchainsword.com/topic/249869-wolf-guard/#findComment-3031061
