Montuhotep Posted March 31, 2012 Share Posted March 31, 2012 Okay, before anyone screams at me, I did use Searchy and found a topic, but unfortunately it dates from years ago and the photo links in it no longer work. Doing a search function for 'Left Handed Bolter' on the entire B & C brings up near every topic with the word 'bolter in, as you'd expect. So. Since I do not want to spend £10.25 on the Legion of the Damned left-hander, anyone got any tips on how to make my own? Link to comment https://bolterandchainsword.com/topic/249945-left-handed-bolters/ Share on other sites More sharing options...
Maligoare Posted March 31, 2012 Share Posted March 31, 2012 Two options, depending what you want. 1. Use a left handed bold pistol arm, swap the bolter for the bolt pistol. 2. As above, except you will need to find a left handed bold pistol arm with a similar pose to the standard bolter arm. Cut at the elbow, shoulder and wrist joints, and re-pose to fit. Some GS ribbing may need to be added here. Next, find a right arm, and repeat the process, but this time mimic the usual bolter left arm. For the hand, you can either sculpt it, or if that's a problem, simply swap the thumb over from a normal bolter left hand. Alternatively, just look at this article in the Librarium. All pictures work for me. Link to comment https://bolterandchainsword.com/topic/249945-left-handed-bolters/#findComment-3029024 Share on other sites More sharing options...
Montuhotep Posted March 31, 2012 Author Share Posted March 31, 2012 The ONE place that I didn't look. ;) I thought a tutorial might be in the tutorials section, but so be it. Cheers Maligore! Link to comment https://bolterandchainsword.com/topic/249945-left-handed-bolters/#findComment-3029029 Share on other sites More sharing options...
