Circus Nurgling Posted April 3, 2012 Share Posted April 3, 2012 Ok just like the title says: what base size do I use for a herald with and without a palanquin? Rules state to use the base that comes with the model, so what size base comes with the other god's heralds, and what base size comes with Epidemius? I have the model, but it was second-hand and without all the bits so I don't know... Thanks in advance. Link to comment https://bolterandchainsword.com/topic/250109-heralds-of-nurgle-what-base-size/ Share on other sites More sharing options...
Brother Ambroz Posted April 4, 2012 Share Posted April 4, 2012 A normal nurgle herald uses the same base as everyone else. Only when you give them a steed or upgrade does their base size change. Link to comment https://bolterandchainsword.com/topic/250109-heralds-of-nurgle-what-base-size/#findComment-3032252 Share on other sites More sharing options...
Rev. Tiberius Jackhammer Posted April 4, 2012 Share Posted April 4, 2012 Unmounted is the size of a Plaguebearer, so 25mm. The herald special character comes on a palanquin; I believe it's mounted on a 40mm base? Link to comment https://bolterandchainsword.com/topic/250109-heralds-of-nurgle-what-base-size/#findComment-3032449 Share on other sites More sharing options...
Circus Nurgling Posted April 12, 2012 Author Share Posted April 12, 2012 Unmounted is the size of a Plaguebearer, so 25mm. The herald special character comes on a palanquin; I believe it's mounted on a 40mm base? Epi comes on a 60mm base, but he's also a special character. The palanquin I modeled fits well on a 60mm base as well, so I suppose I'll go with that, though Epi being unique it may make him stand out from other Heralds on Palanquin, yes? Anyway here's pics of the rough model. Very WIP at this stage, just the concept really. Still needs all the putty, guitar wire, and nurglings added to it. It really doesn't need a base at all... http://i899.photobucket.com/albums/ac197/gfan360/035.jpg http://i899.photobucket.com/albums/ac197/gfan360/036-1.jpg Link to comment https://bolterandchainsword.com/topic/250109-heralds-of-nurgle-what-base-size/#findComment-3037661 Share on other sites More sharing options...
