MajorKhaos Posted April 14, 2012 Author Share Posted April 14, 2012 I'll be working on it tonight. Link to comment Share on other sites More sharing options...
MajorKhaos Posted April 16, 2012 Author Share Posted April 16, 2012 A bit late, but here's the starters... Initially, I started off with one mini, pics 2-5, But ended up completely buggering it up. so he's gone into the naughty corner. Pics 6 & 7 are a painting reboot. Both with Blackfire Earth for the basework and one has a imperial primer thrown at it to see what it's like. The primer is not bad, but As you may be able to see from the mini, you can't just slap it on and let it level itself out, if you're not creful you can get it a bit thick and have brush strokes visible. If I need to use a primer, I'll probably stick to using Alclad Black primer instead. Once the texture paint dries, I'll start putting some mechanicus standard grey down on both. http://www.flickr.com/photos/majorkhaos/se...57629462062238/ Link to comment Share on other sites More sharing options...
Chapter Master Ignis Domus Posted April 16, 2012 Share Posted April 16, 2012 I like the look of them in terms of colors. Seems like I'll be able to keep about the same scheme, but with a much cooler gold. Link to comment Share on other sites More sharing options...
MajorKhaos Posted April 16, 2012 Author Share Posted April 16, 2012 Here's a pic of the Mechanicus Standard Grey over the primer. This one really is a bit buggered as the primer was slapped on too thick and the base paint is not exactly thin either, but it should give you ad idea of the colour, compared to a stock plastic one. Once the paint is dry, I'll wash it with Nuln oil and then put some other colours / metallics down to tidy it up as best I can. Link to comment Share on other sites More sharing options...
MajorKhaos Posted April 16, 2012 Author Share Posted April 16, 2012 Extreme close up! Link to comment Share on other sites More sharing options...
MajorKhaos Posted April 16, 2012 Author Share Posted April 16, 2012 A bit of Leadbelcher and Balthasar gold. As a base colour for gold, it's very, very nice... Link to comment Share on other sites More sharing options...
