Valthex power whips
Use hot water, brother, not a hairdryer. The hairdryer might warp the resin whereas the water will not.
Get yourself a bowl of fairly hot water and soak the parts in it before trying to carefully bend them to the desired position. If you find they feel resistent to bending, don't push it. Get more hot water and keep trying. Just be VERY careful. :)
Hope this helps.
I used the hot water technique to bend these. Hold them in some hot water with tweezers, then move slowly into shape and as mentioned if you feel like they are about to break - stop - warm them in the water again. You could keep some cold water in a cup or whatever to set them if you wanted to.
http://i3.photobucket.com/albums/y87/paulj1965/GW%2040K/PC222920.jpg
