has anyone tried to truescale chaos marines?
Eccentualy the process for True/Art Scaling Chaos marines is identical Imperial marines, you just substitute imperial bits for chaos ones.
Heres some links for you
Lamenters Art-scale tutorial
Lamenters Art-scale Chaos Marines
Cheers,
Jono
thanks for the links everyone. id seen lamenters page on truescaling imperials but hadnt seen doghouses or akan's reavers or lamenters chaos marine. i need a side project and really want to try mny hand at it as it really looks amazing.
I did a True Scale effort for Maverick Prime's most recent conversion challenge. I didn't make it to the competition because I forgot to write the story to go with it, but I did get the model done, pictures of which can be found here.
With Arminius here I forgot to use Terminator upper arms, so they look a little short. And maybe I wouldn't use the large daemon heads from the tank sprue on the backpack again, and the putty work on the abdomen leaves a little to be desired, but I think I've got a quick and easy scaling method going on there. I forget who's tutorial it was I based it off of, though.
A long time ago,
Also,
Things that don't belong in the tutorials area:
Questions that aren't a tutorial for starters.
"What color do I highlight Scorpion Green with?" Isn't a tutorial or even a tutorial question. That is for General PCA Questions.
"Does anyone want a tutorial on X?" If you have a tutorial then just post it. You can find tutorials that people are looking for in the Tutorial Requests Thread.
"Where can I find/buy model/paint/tool X?" Again this is something for General PCA Questions.
Basically if it isn't something that isn't a step by step instruction it shouldn't be in here!
Topic moved. :D
