BLACK BLŒ FLY Posted April 15, 2012 Share Posted April 15, 2012 Okay serious question. Of course when it comes to terrain you should always agree ahead of time how it works. So this question is 'How would you play it?'. The text diagram below features a common ruin from GW we often use: ______________________ |xxxxxxxx xxxxxxx xxx |xxxxxxxx xxxxxxx xxx | |xx |xx |xx | Legend: _ outer wall | outer wall xx upper ledge Basically you have two walls that form a corner and there is no floor underneath - just open ground - you've just got the two walls attached at the corner with the upper ledges on the inside (the inside area is within the two walls and underneath the upper ledges). Q: Would you play the ground level inside as difficult terrain or not? Note - Typically I play area terrain as pieces that have some type of floor/ground attached as a base. G :D Link to comment Share on other sites More sharing options...
Jacinda Posted April 15, 2012 Share Posted April 15, 2012 Anything we say is going to be in the realm of "house rules" just because that is the way buildings are handled in RAW. We usually do not call those pieces Area Terrain. That said, every piece of terrain we use has a base of some sort. Hills are themselves the base. Forrest, swamps and brush will have felt templates laid down and the appropriate decorations (trees or lichen brush) placed on the template base. These are the only things we call Area Terrain. The large GW ruins are on a base and that base denotes the area that is difficult terrain; moving anywhere on the base on ground level or above is difficult terrain but it is not Area Terrain so it is possible to not get any cover from the ruin. But that is all just our convention. You need to discuss the terrain with your opponent. You could claim that same piece is impassable. You could agree to treat the ground floor as difficult terrain and the upper levels as dangerous if you want. Terrain and especially buildings only have whatever rules you give them before the game starts. Link to comment Share on other sites More sharing options...
BLACK BLŒ FLY Posted April 15, 2012 Author Share Posted April 15, 2012 I just found on page 82 of the BRB that ruins not mounted on a base don't count the ground level as difficult terrain. G ^_^ Link to comment Share on other sites More sharing options...
Seahawk Posted April 15, 2012 Share Posted April 15, 2012 Yep, if it's not on a base it's not difficult terrain. Only the upper floors are. Link to comment Share on other sites More sharing options...
