Inquisitor 117 Posted April 17, 2012 Share Posted April 17, 2012 Does anyone have a good mix for the (new) citadel color for airbrushing? Link to comment https://bolterandchainsword.com/topic/250902-painting-the-pack/ Share on other sites More sharing options...
Rune_Priest_Rhapsody Posted April 17, 2012 Share Posted April 17, 2012 There was an article in the newest WD that had a bunch of painting jumbo. I don't recall what colors where used however... End of Line Link to comment https://bolterandchainsword.com/topic/250902-painting-the-pack/#findComment-3041272 Share on other sites More sharing options...
Inquisitor 117 Posted April 17, 2012 Author Share Posted April 17, 2012 I was actually wondering if they needed to be thinned or if they can go into an airbrush fresh from the paint cups? Link to comment https://bolterandchainsword.com/topic/250902-painting-the-pack/#findComment-3041298 Share on other sites More sharing options...
Toasterfree Posted April 17, 2012 Share Posted April 17, 2012 always thin and its going to be different everytime. you want your paint to be about the consistency of 1% milk Link to comment https://bolterandchainsword.com/topic/250902-painting-the-pack/#findComment-3041300 Share on other sites More sharing options...
Inquisitor 117 Posted April 21, 2012 Author Share Posted April 21, 2012 Ok, are there any good thiners or will a general acrylic thinner do? Link to comment https://bolterandchainsword.com/topic/250902-painting-the-pack/#findComment-3044408 Share on other sites More sharing options...
Toasterfree Posted April 21, 2012 Share Posted April 21, 2012 i dont know of any good thinners, but you can use rubbing alcohol or distilled water Link to comment https://bolterandchainsword.com/topic/250902-painting-the-pack/#findComment-3044416 Share on other sites More sharing options...
GalaxyChief Posted April 21, 2012 Share Posted April 21, 2012 Do not use rubbing alcohol with GW paints, they will curdle up in your air brush. You can use distilled water as mentioned. I have also found that the thinners made for Model Master acrylic paints works fine as well. Link to comment https://bolterandchainsword.com/topic/250902-painting-the-pack/#findComment-3044809 Share on other sites More sharing options...
Inquisitor 117 Posted April 21, 2012 Author Share Posted April 21, 2012 What's a good ratio? 1:1? Link to comment https://bolterandchainsword.com/topic/250902-painting-the-pack/#findComment-3044813 Share on other sites More sharing options...
GalaxyChief Posted April 21, 2012 Share Posted April 21, 2012 Make it like milk is what I have been told and try to achieve. There is no set ratio for GW paints. I just thin it till it "look's right then test spray..... and add more paint/thinner as needed. Link to comment https://bolterandchainsword.com/topic/250902-painting-the-pack/#findComment-3044815 Share on other sites More sharing options...
Toasterfree Posted April 22, 2012 Share Posted April 22, 2012 Make it like milk is what I have been told and try to achieve. There is no set ratio for GW paints. I just thin it till it "look's right then test spray..... and add more paint/thinner as needed. qft. on the old foundations its almost a 2:1, but on the other ones sometimes its a 1:1 other times its like a 1.5 or 1.25 or 1.75:1 ratio. its never the same per pot Link to comment https://bolterandchainsword.com/topic/250902-painting-the-pack/#findComment-3044829 Share on other sites More sharing options...
