Grotsmasha Posted April 19, 2012 Share Posted April 19, 2012 This will be the place where I'll post all things Dark Angels excluding my true scale stuff. 1st up, 25th Anniversary Consecrater Captain Just got to paint the backpack, pistol power cables annddd maayyybbeee attempt the chapter symbol on the right shoulder pad. Also, this is the first time....ever....that I've done highlights...and have left them on. The rest of these guys are 'bigger' marines, all of them are still WIP Captain and his command squad and some random Sgts and my attempt at a plastic Asmodai All C&C is welcome, cheers, Jono Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/ Share on other sites More sharing options...
Polythemus Posted April 19, 2012 Share Posted April 19, 2012 I think your painting is very clean. I also think that the models color choioce is very dark, and without any highlighting loses something in the photo. The models appear kind of flat as a result, try using some lighter shades of a similar color to add a little light sourcing and i think that they will look great! Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3043010 Share on other sites More sharing options...
Isiah Posted April 19, 2012 Share Posted April 19, 2012 Some models are WIP so hence the lack of highlights ;). Awesome sauce Grotsmasha that 25th Anniv model looks so cool. Eye lenses really pop. Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3043208 Share on other sites More sharing options...
Grotsmasha Posted April 20, 2012 Author Share Posted April 20, 2012 .....is there any reason why I couldn't/shouldn't paint different coloured eye lenses within a squad? I was thinking I could do this to represent the marines using different viewing filters. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3043853 Share on other sites More sharing options...
Wolf Priest Haelaeif Posted April 20, 2012 Share Posted April 20, 2012 I think different eye lenses is a cool idea. I do it on my sergeants anyway since my normal guys have red lenses and my sergeants have red helmets - so they get yellow lenses. I was considering trying the yellow lenses on normal marines, too. Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3043858 Share on other sites More sharing options...
Brother-Sergeant Bohemond Posted April 20, 2012 Share Posted April 20, 2012 I would say there is no reason not too do it, other than disunity within the squad. All I can suggest is you try it out and see what it looks like, if it detracts or adds to the overall look - or does neither. Then see what you like more. And, before I forget, awesome looking anniversary model, I love what you have done with it, I really like the Consecrators Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3043859 Share on other sites More sharing options...
Tamwulf Posted April 20, 2012 Share Posted April 20, 2012 I don't see any problem with painting the lenses on your helmets different colors. I'd avoid some of the more unusual color combinations and maybe stick with reds, greens, and blues. Try and make them a bit darker to blend in with the green power armor. If they are wearing robes, you could probably get away with brighter colors. It depends on whether or not you want the eye lenses to be the focus of the model, in which case the brighter, more contrasting, the better. A note about your painting: It's probably the lighting and camera, but your paint looks really thick. Do you thin it down with water at all? I'd recommend with GW paints (especially some of the newer GW base colors) at least 50% water/paint. Multiple thin layers of paint are way, way better then a single thick coat. Your metallics are the worst offenders. Have you tried any of the GW Washes? Err, GW renamed them Shades for some reason, but wash is a better descriptor even though you are shading the model. Anyways- wash your metallics with either GW Nuln Oil (old GW Badab Black) or GW Agras Earthshade (old GW Gryphon Sephia). For the Gold, shade them with GW Seraphim Sepia (old GW Gryphon Sepia). This stuff is pure talent in a bottle and the best thing GW has ever made. You can use the stuff straight out of the bottle, but I like to thin it down a bit, wash a layer on, let it dry, add another layer, etc. etc. until I get the shade or effect I'm going for. It takes a bit to dry, let it or you'll get some very interesting wet blending areas. Once dry, I go back over it to bring the highlights back. It dries very mat, so it will dull down your metallics a bit. Don't worry if it looks really dark when you brush it on, it dries very translucent unless you add a lot of layers or really goop it on. Thin layers are the key! Also, unlike an ink, this stuff doesn't flow into cracks and crevasses. You have to paint it where you want it. Another good use of the Shades is to recolor your metalics. Like say you want a red sheen to your sword? Paint on a bright silver (GW Runefang Steel, P3 Steel, old GW Mithril Silver), then wash it with a thinned down old GW Baal Red or the new GW Carroburg Crimson. This will give it a very nice red sheen effect. Incidentally, you can make your own washes/shades by using a high density pigment paint (like P3 or Reaper HD) and lots of mixing medium. Uses washes/shades/glazes will take your painting to the next level and you will not be disappointed. Keep painting! :wacko: Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3044042 Share on other sites More sharing options...
Grotsmasha Posted April 20, 2012 Author Share Posted April 20, 2012 Hey guys, @ Polythemus: I've highlighted one, just for you :P @ Isiah and Brother Sergent Bohemond: Cheers !!! @ Tamwolf: I do thin my paints....now, excluding the 25th Anv, these guys were painted a while back. I love washes/shades, just out of Bada......Nuln Oil now I guess. And a newbie Disciple of Caliban cheers, Jono Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3044283 Share on other sites More sharing options...
Polythemus Posted April 21, 2012 Share Posted April 21, 2012 You sir are a gentleman and a hell of a good painter my hat is off and stuffed firmly in my mouth, nice work! I gotta say i really like the effect of metal on the backpack for the disciple of caliban and the lenses kick ass. Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3044358 Share on other sites More sharing options...
Grotsmasha Posted April 21, 2012 Author Share Posted April 21, 2012 So, which pack would you like to see on the Anniversary Captain? Right, or Left? 3rd option, Cheers, Jono Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3044461 Share on other sites More sharing options...
EPK Posted April 21, 2012 Share Posted April 21, 2012 My vote is for option 3. It has that old school feel like option 2, but with more detail befitting a captain. Of course there is a good argument for option 1 as well. The wings will definitely scream DA and help him stand out... Okay, it's between option 1 and 3... I think either would work well for a chaplain too. I'm gonna stick with 3, mostly because it's the old style that this 25th Ann. model is based on. Maybe you can put a DA icon on top? Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3044650 Share on other sites More sharing options...
Interrogator Stobz Posted April 21, 2012 Share Posted April 21, 2012 I'd go option 3 as well. Put 'Cyphers' one on that epic version of Asmodai, for some extra gothicness goodness. <_< stobs Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3044780 Share on other sites More sharing options...
Grotsmasha Posted June 4, 2012 Author Share Posted June 4, 2012 I guess its time to throw up my ETL progress, RED = Not Started/Base Coated YELLOW = In Progress GREEN = COMPLETE !!!!! So I upgraded my original vow and now it reads, “I, Grotsmasha, answer the challenge of the Unforgiven and vow to complete: 1 x Mortis pattern Contemptor Dreadnaught => 2 x Twin-Linked Lascannons => 1 x Cyclone Missile Launcher Points: 220 1 x Supreme Grand Master Azrael Points: 225 1 x Interrogator-Chaplain (Asmodai) =>Plasma Pistol Points: 135 Original Vow: 355/580 Complete -------------------------- VOW EXTENSION 1 -------------------------- 2 x Company Veterans Squads => 5 Veterans with twin Lightning Claws, Combat Shields and Meltabombs. ==> Razorback with Pintle Storm Bolter, Dozerblade, Extra Armour, Twin Linked Lascannons. Points: 405 => 5 Veterans with Power weapons, Storm Shields and Meltabombs. ==> Razorback with Pintle Storm Bolter, Dozerblade, Extra Armour, Twin Linked Lascannons. Points: 380 Total Points Added: 785/785 -------------------------- VOW EXTENSION 2 -------------------------- I'm adding; 1x Company Master (GotC) => Storm Bolter, Plasma Pistol, Twin Lightning Claws, Melta Bombs and Jump-pack Points: 175 These next two *need to be painted as Fire Hawks for A Tale of 17 Gamers, so they might as well count here to 1x Interrogator-Chaplain =>Plasma Pistol, Melta Bombs and Jump-pack Points: 160 1x Company Master => Plasma Pistol, Power Fist, Melta Bombs and Jump-pack Points: 165 Total Added Points: 500/500 Compete TOTAL POINTS: 1640/1865 Complete from Codex: Dark Angels on or before August 15, 2012. Success will bring eternal glory to the Sons of the Lion, and failure will doom me to bear the sign of damnation until the year-end.” Ok, so here's the starting pics, -------------------------- VOW EXTENSION 1 -------------------------- I don't have a pic of the 2nd razor as the turret is still to be built. -------------------------- VOW EXTENSION 2 -------------------------- (I know he's not pictured with JP, but his packs are magnetized) Completed Interrogator-Chaplain (Asmodai) 2x Completed Company Veterans Cheers, Jono Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3078029 Share on other sites More sharing options...
DucAvieux Posted June 4, 2012 Share Posted June 4, 2012 Those are some rear end kicking veterans! I love the MkIV armor with lightning claws! Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3078043 Share on other sites More sharing options...
Grotsmasha Posted June 8, 2012 Author Share Posted June 8, 2012 Another one bites the dust !!!!!! 1x Guardians of the Covenant Company Master => Storm Bolter, Plasma Pistol, Twin Lightning Claws, Melta Bombs and Jump-pack Cheers, Jono Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3080659 Share on other sites More sharing options...
Grotsmasha Posted July 5, 2012 Author Share Posted July 5, 2012 Although not a Dark Angel, my Fire Hawk Captain for the ETL has been completed, and can be seen HERE in my ETL thread in the WIP forum. With a little bit of effort, the Contemptor should also be completed this evening. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3110950 Share on other sites More sharing options...
Captain Semper Posted July 6, 2012 Share Posted July 6, 2012 So, once you get the Mortis done, you'd still have Azzy and two 5-strong squads with their assorted razors, right? Your Company Vets look amazing btw! :D Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3111284 Share on other sites More sharing options...
Grotsmasha Posted July 6, 2012 Author Share Posted July 6, 2012 So, once you get the Mortis done, you'd still have Azzy and two 5-strong squads with their assorted razors, right? Your Company Vets look amazing btw! ;) Yep, spot on. I've actually got a total of 4 finished vets, two from each squad, but have decided to put up pictures once the squads are done. For the first Razor, theres just highlights, turret and tracks to finish. Azzy has been undercoated at least. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3111416 Share on other sites More sharing options...
elmo Posted July 6, 2012 Share Posted July 6, 2012 Nice vets :P Now I want to see the group photo. Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3112155 Share on other sites More sharing options...
Grotsmasha Posted July 10, 2012 Author Share Posted July 10, 2012 Contemptor Done !!!! TOTAL POINTS: 855/1865 Complete Cheers, Jono Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3117155 Share on other sites More sharing options...
Captain Semper Posted July 11, 2012 Share Posted July 11, 2012 WOW!!! What a a Contemptor! The pose alone is so bada$$, it's like "Die heretic, die"... :) Keep going Jono, you still have 1k points to go! ;) Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3117479 Share on other sites More sharing options...
BigGumbo Posted July 11, 2012 Share Posted July 11, 2012 Love the Contemptor, brother! :lol: Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3117948 Share on other sites More sharing options...
Grotsmasha Posted July 11, 2012 Author Share Posted July 11, 2012 Cheers Captain Semper and BigGumbo!!!! The pic doesn't really show the colour contrast properly, the purple and blue stand out a bit more irl. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3117988 Share on other sites More sharing options...
Grotsmasha Posted July 17, 2012 Author Share Posted July 17, 2012 Ahhhhh Yeeaaaahhhh!!!!! Lightning Claw Veteran Squad Complete, and with a little effort their Rhino will make it later today. with a little luck, I'll be right back with their Razor. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3124859 Share on other sites More sharing options...
Grotsmasha Posted July 18, 2012 Author Share Posted July 18, 2012 .....and done, I present 1x Razorback. TOTAL ETL POINTS COMPLETED: 1260/1865 Cheers, Jono Link to comment https://bolterandchainsword.com/topic/251028-grotsmashas-dark-angels-and-successors/#findComment-3125977 Share on other sites More sharing options...
