Summoning and servo-skulls?
landoro
Hello!
If you use The Summoning within a servo-skull do you roll on less dice for scatter? Working on a list which has this as my main tactics for movement. Deep strik a librarian in and summon everyone else close. Cheap Inqusitor to use psychic communion to help the Librarian in.
Skulls will make this much easier.
Anyone heard any offical on this? If not how do you play it? So far my small group (3 people) have said yes, now i am going to my first large tournament (or I hope I will) so just wanna hear what most people say.
Have fun.
Landoro
https://bolterandchainsword.com/topic/251211-summoning-and-servo-skulls/
I play that it does reduce scatter, as that's what servo skulls do. Using the summoning you place the unit being summoned as if by deepstrike.
However, it may be worth contacting the tournament organiser and asking them, as it might be a shock if you are planning for it and they rule that you can't...
Hello!
Have fun.
Landoro
summoning is NOT deep strike. there are plenty of things that make stuff move by the DS rules, but are not DS (jumping out of storm raven, veil of darkness, tempest gate). so no, skulls do NOT reduce the scatter from summoning.
The Summoning *is* Deep Striking (For all intents and purposes, much like jumping out of a Flat Out SR). You place a unit on the table using the Deep Stike rules. If you used The Summoning versus a GK army, and Summoned within 12" of Warp Quake, you would trigger a mishap.
Servo Skulls work with The Summoning. The reason Teleport Homers don't is different.
the summoning is NOT deep strike. its no where near deep strike for any intents and purposes. it uses the deep strike rules, but is not a deep strike. just like viel of darkness is NOT a deep strike, but uses the deep strike rules. unless the skulls say something that it reduces the scatter of everything near it, which not near dex so i cant look....
It uses the Deep Striking rules.
For all intents and purposes, it's Deep Striking. That's why it uses the Deep Striking rules.
You can mishap, you scatter. Exactly like deep striking. Locator Beacons (if we had them) would help. Mystics work. Servo Skulls work. Becuase they all work on units that are deploying using the Deep Striking rules.
What you can do, is try to wrangle a RAW discussion about 'deployment', which I'm not going to get into.
Edit:
Exact rules;
Servo Skulls
A friendly unit arriving by Deep Strike rolls 1d6 less for scatter
The Summoning
The chosen unit is removed formt he tabletop and immediatley placed anywhere within 6" of the Librarian using the Deep Stirke rules
Deep Strike
and then deploy them as follows
Edit:
Exact rules;
Servo Skulls
The Summoning
Deep Strike
ARRIVING by deep strike, the unit being summoned is NOT arriving it is already there. it has already been on the table top. so therefore it is NOT being deployed by deep stike. therefore is NOT a deep strike
I would say yes. As mystics are faq'd to prevent scatter. That said I'm not sure if deep striking him the summoning will work well if at all. First summoning states it must be used at the start of the movement phase so I'm not sure you can do it the turn you arrive. Second you can only summon one unit per turn so you are paying a lot of points to move maybe 1 unit. I've been using summoning recently, I find I works better with a Libby embarked in a vehicle with a mystic.
