Some rule questions
Roma
Can an independent character in a unit of interceptors teleport with them?
No, as you must move at the slowest speed, and the IC can't teleport.
Can hammerhand be cast by an IC multiple times?
Not by a single IC, as you can't (try to) cast the same power twice, but you can have multiple ICs attached to the same unit, each casting Hammerhand.
If a character+unit cast hammerhand, do they get +2 strenght each?
Yes, it stacks with each other and with Might of Titan as well.
Grand strategy, can it be used on the model with the rule (i.e grand master)?
No, as it can't be used on models with the Independent Character special rule. The only exception is Grand Master Mordrak if he doesn't bring any Ghost Knights, but then, why bring him at all?
Thanks.
You're welcome.
