converting scythes
seconding what Jofus suggests. depending on scale you can use the monsterous creature sized ones or some off hormagaunts (the later may be a little small for terminators but can work for PA). they work wel when using the haft from thunder hammers or power axes
if you dont want to go that route a bit of plasticard works too
