khurdur Posted May 7, 2012 Share Posted May 7, 2012 Hey there...we were playing a game today and this came up....to hit an IC with a units powerfist, can it hit him from 2 inches away or do they have to base to base? Also, can the character keep back or is he forced to push to the front of his unit to fight? Link to comment Share on other sites More sharing options...
greatcrusade08 Posted May 7, 2012 Share Posted May 7, 2012 hi mate ill try and make it as easy as possible to explain, as it can cause confusion. in combat an independant character forms a seperate unit, he can only strike at what he is in B2B with. your own unit will need a model in B2B to be able to hit him back, after that all normal rules apply, if the powerfist was within 2" of a model in B2B with the Ic and not otherwise engaged himself, he is free to gimp him. also when assaulting Ics are moved first, and the same applies to pile in moves after each round of combat Link to comment Share on other sites More sharing options...
breng77 Posted May 7, 2012 Share Posted May 7, 2012 also when assaulting Ics are moved first, and the same applies to pile in moves after each round of combat You got it right except for this part. Ics are only required to move first when defenders react or during pile ins. During an initial assault there is no rule stating ics move first. Link to comment Share on other sites More sharing options...
dswanick Posted May 7, 2012 Share Posted May 7, 2012 also when assaulting Ics are moved first, and the same applies to pile in moves after each round of combat You got it right except for this part. Ics are only required to move first when defenders react or during pile ins. During an initial assault there is no rule stating ics move first. And the IC is required to move first and get into base contact only so long as it is possible. If an IC is completely surrounded by 6 models in his attached unit, and those six models are all already in base contact with an opponent(meaning they don't have to make a reaction movement), then the IC won't be able to move. The IC is the one in the middle of this example. After the attacker makes his assault moves, the unit's models have no movement to make and therefore the IC can not move to engage anyone and will sit the resulting combat out. http://i1127.photobucket.com/albums/l634/dswanick/one.png Link to comment Share on other sites More sharing options...
Jolemai Posted May 8, 2012 Share Posted May 8, 2012 If an IC, and just an IC is in combat with an enemy squad then the entire squad can hit him. If an IC and a friendly squad are in combat with an enemy squad then only those enemies within two inches can hit him. Correct, or? Link to comment Share on other sites More sharing options...
ShinyRhino Posted May 8, 2012 Share Posted May 8, 2012 If an IC, and just an IC is in combat with an enemy squad then the entire squad can hit him.If an IC and a friendly squad are in combat with an enemy squad then only those enemies within two inches can hit him. Correct, or? Sort of. The first statement is correct. The second one is partially correct. It should be "If an IC and a friendly squad are in combat with an enemy squad then only those enemies within two inches of a model in base contact with the IC can hit him, except those that are in base contact with only the friendly squad members." A model must attack the unit with which it is in base contact. If it is base contact with more than one unit, it can choose where its attacks fall. Link to comment Share on other sites More sharing options...
breng77 Posted May 8, 2012 Share Posted May 8, 2012 or If an IC and a friendly squad are in combat with an enemy squad then only those enemies within two inches and not in base to base with another enemy model . can hit him Link to comment Share on other sites More sharing options...
