Wolves without the growl
Smallboy
I dont believe in GW's habbit of "here's our new army these are much harder than anyone else out there"
If you were going by that rule you'd be doing grey knight anyway.If you restricting yourself to the Codex Marine Codex then why not just create a chapter of your own? You'd lose the charactor of the Wolves by having tac squads and the like.
New?? Space Wolves?? Are you lost?
As for conforming SW packs to SM structure, there's no point. The reason for the separate codex is because SWs are structured completely different. Use the models; make your SM army. They simply won't be Wolves in any capacity other than looks, so it doesn't matter what we say.
Hi guys, I'm looking into doing a Space Wolf army (1500 points) but using the standard SM Codex, anyone else here done it? Is it easy enough for Grey Hunters to stand as Tac Squads and Blood Claws to be Assault Marines?
Your models, your army, do as you see fit. ^_^
I believe that DV8 had a Space Wolves army using C:SM at one point, before the current Wolves 'dex was released. If I recall correctly, though, it mostly used standard Space Marine models, with the occasional wolf tail added here and there, as the current models were not available at the time.
I may be misremembering, of course.
Your models, your army, do as you see fit. ;)
You are correct.
I used Pedro Kantor, Sternguard, and Tactical Squads in Rhinos to represent massed Grey Hunters, expecting that I would be able to use lots of Bolter-armed marines and Rhinos with the new Space Wolves Codex (the old book sucked in 5th Ed, and C:BA and C:GK did not exist at this point, making C:SM one of the more powerful books at the time). Transitioning the army from C:SM to C:SW was incredibly easy, and just required the inclusion of some Scouts and Land Speeders to round out the army.
I will eventually be looking to add more feral and barbaric looking Space Wolves to my Great Company though.
DV8
Your models, your army, do as you see fit. B)
You are correct.
DV8
Woo hoo. Now those I want to see for certain.
I just don't understand why?
GH are far (FAR) better than regular tac marines.
And BC are probably better than assault marines (especially if led by a Wolf Priest or Wolf Guard) (Blood Angels are better, but that's not C:SM either).
But, it's your army...go forth and blaspheme away, heretic!! ;)
if you want to use a less powerful dex you should use CSM rather than C:SM
You can get the BP,BG,CS equipment counter attack
At least the list will have the right feel using tac marines as GH is just wrong they are puny in CC and just dont fit the fluff or style of the wolves you might as well use necrons .......
I understand that you're aiming to make every legion army...But wouldn't you RATHER have the codex-specific legions using their won books???
I'm not trying to be mean, but it sounds like all you want is various shades of space marines all under the same book, which doesn't make any sense to me. If anything, you should take the legion specific codexes and use them to your advantage. Build marines that can be used as either Blood Angels or regular Space Marines so that you have DOUBLE tactical versatility instead of limiting yourself to having everything using a single codex.
Take for example my army: Night Lords (AVE DOMINUS NOX!!). I hate the chaos codex, WITH A PASSION! So seeing that, I realized that I could use a different codex better suited to the Night Lord's traits, such as the Blood Angels or the Space Wolves (That's why I'm in this forum ;)). That way I could use either codex to my advantage and also play with the playstyles and things that I like from both books.
Whatever you choose to do (and I vote NO for using wolves as codex astartes marines), Happy hunting to ya
