brainwashed Posted May 18, 2012 Share Posted May 18, 2012 I've just gone through the Space Wolves Codex, the GW 1.2 Space Wolves FAQ and searched the B&C forums with no results but I'm sure this has been asked before. When a Wolf Guard in Terminator armor and a Cyclone Missile Launcher join a Long Fang pack, do they benefit from Fire Control and can fire at a third target? Please state a source as I need to cite a rule. Thanks for any help.A Link to comment https://bolterandchainsword.com/topic/252566-fire-control-and-wolf-guard-with-cyclone-missile-launcher/ Share on other sites More sharing options...
Khine Posted May 18, 2012 Share Posted May 18, 2012 As the WG becomes part of the pack he is subjected to the limitations of the pack. On page 28 it states " .. the unit may split its fire and fire at two different targets instead of one." This means that the unit (including the WG) can only fire at two separate targets, MAX. Link to comment https://bolterandchainsword.com/topic/252566-fire-control-and-wolf-guard-with-cyclone-missile-launcher/#findComment-3064071 Share on other sites More sharing options...
brainwashed Posted May 18, 2012 Author Share Posted May 18, 2012 Thanks Khine! Link to comment https://bolterandchainsword.com/topic/252566-fire-control-and-wolf-guard-with-cyclone-missile-launcher/#findComment-3064077 Share on other sites More sharing options...
Valerian Posted May 18, 2012 Share Posted May 18, 2012 That's correct, and the same thing goes for any attached Independent Characters. So, you could have a Long Fang pack, plus assigned Wolf Guard, plus attached Rune Priest (for example). The Squad Leader can't shoot (in order to use the ability), but all of the others can, and you get to assign the shots between whatever two (no more than two) targets you wish, in any combination. You just have to declare which models are shooting at which targets before you begin - no changing your mind once the dice has started rolling, just because you didn't get the results you were hoping for! Valerian Link to comment https://bolterandchainsword.com/topic/252566-fire-control-and-wolf-guard-with-cyclone-missile-launcher/#findComment-3064084 Share on other sites More sharing options...
