Space Marine Veterans MKII into Wolves...
Zackya7x
Hey guys, couple of questions for you guys again...
So, I recently discovered that I have an unopened Space Marine Veterans MKII laying around my room. I want to add it to my Space Wolf army but I don't know how to equip them or use them in my army. Should I use them as Wolf Guards? Independent characters? Rune Priests? Wolf Priests? If so, how should I equip them and convert them (I'll search on the web, but you could give me tips here, too!).
I know that it's all up to me, but I want the forum's opinion. :)
Thank you!
You could use the method that people do pre hersey wolves and make them into WG. I probably wouldn't put them as IC because they are more likely to have more elaborate armour.
If your any good with green stuff you could add charms and other wolf symbols/iconography too them. If not just use bits from the other kits we have to augment them. Using helmetless heads is always a sure fire way to wolf up a model. I recommend the ones from the new thunderwolf cav box, some of those heads are really cool and would work really well for WG.
Once you paint them the right colors, they'll look fine as Space Wolves without any significant changes. I used at least a couple models from the Veterans Mk 1 set, and they fit in just fine. I'll see if I have a pic somewhere, and will edit it in.
Valerian
EDIT: easiest thing from my iPhone was just to set the pic as my avatar, so just look at that.
