Henchmen
http://i434.photobucket.com/albums/qq70/Myen_Shi/2012update2-squat.jpg
That is all :lol:
I am also planning an Eldar Harlequin (DCA) and a converted Fire Warrior (warrior henchman) but those will come later. My collection of IST's, some odd Necromunda models and Priests, Sanctioned Psykers, Crusaders, etc is usually sufficient. Cyber Mastiff, Servo skulls, Chiurgeons.. most all the official GW options really. Need a few things still to add to the collection.
https://bolterandchainsword.com/topic/253406-henchmen/#findComment-3074733
I'm in the process of kit bashing quite a few henchmen together. I picked up a box of dark eldar witches for DCA. Im pretty particular about wysiwyg, so I have to convert the splinter pistol arms to accept a power weapon. the crappy part is that any of the marine bits I have look way too big, so ill have to figure that out.
For warriors I'm using just some cadian stormtroopers, and again I'm big into wysiwyg, so i didn't want to use the lasguns as hotshots, because its a bit pricey points wise. Im using some scout arms to fill in the gap there (with bolters) and some marine meltas, with a bit of snipping to fit them into the guard arms.
For crusaders I'm using bretonian men at arms, and I haven't really looked at them much, but ill need to replace that pol-arm with something more modern. If I can get them done (assembled and sprayed) this week, ill post some pics
https://bolterandchainsword.com/topic/253406-henchmen/#findComment-3077256
Here is a list of the henchmen I am assembling:
Warriors: Catachans, and I use T-guns from MaxMini as Stormbolters.
Jokaeros: Catachans with grenade launchers. Different types of grenades = Las, Melta or HF.
Heavy bolter servitors: Catachans with Miniguns from MaxMini
DCA: Witch Elves
Daemonhosts/Psykers: Flagellants. I play them al as a kind of psyker. They hate themselves for what they are and only wishes do die in battle for their beloved Emperor.
Crusaders: the bodies from some High Elves with cloak and Halberd, and Black Lotus Heads and shileds from MaxMini.
https://bolterandchainsword.com/topic/253406-henchmen/#findComment-3077308
for my warriors i use IG cadian shock troops with the chainsword arm and laspistol. got the arm parts cheap as few IG players ever use them.
For DCA i use DE Wyches. Cut of the pistol (not the hand) and glued trimmed down Nemesis falchions to the hand/pistol grip. looked good and not so De after trimming off all the spikey bits.
https://bolterandchainsword.com/topic/253406-henchmen/#findComment-3077336
