Mimir Posted June 1, 2012 Share Posted June 1, 2012 Hello Not sure if this came up earlier, but can a Grey Knight unit equipped with personal teleporters (Interceptors and Dreadnight) make it's 30'' move as part of coming from reserves in Dawn of War deployment, appearing that far from GK player's table edge? Or is this "instead of moving normally" special move and unit must enter the table normally and can teleport the next turn? Link to comment Share on other sites More sharing options...
dswanick Posted June 1, 2012 Share Posted June 1, 2012 I can't find any reason why a unit couldn't use the special move on it's DoW movement. And I'd be hard pressed to argue that it shouldn't be allowed given the FAQ for Necrons : "Q: Can a veil of darkness be used instead of moving onto the board when a unit arrives from reserve? (p84) A: Yes.", C:N FAQ Link to comment Share on other sites More sharing options...
DarkGuard Posted June 1, 2012 Share Posted June 1, 2012 I agree with dswanick. Turbo-boosters I believe can also be used for bikes and that's not a normal move. The only time shunting is explicitly forbidden seems to be when scouting, and that's for obvious balance issues. You should be fine to use it for DoW though. Link to comment Share on other sites More sharing options...
Acebaur Posted June 2, 2012 Share Posted June 2, 2012 I can't find any reason why a unit couldn't use the special move on it's DoW movement. And I'd be hard pressed to argue that it shouldn't be allowed given the FAQ for Necrons :"Q: Can a veil of darkness be used instead of moving onto the board when a unit arrives from reserve? (p84) A: Yes.", C:N FAQ Other Armies FAQ's have no relevance whatsoever. That said, I do agree that they can do it, as Bikes can use their turbo boost as Darkguard said. Also they do move more or less normally when they come in(vehicles have to make it fully onto the table), they just technically start their move off the board. Link to comment Share on other sites More sharing options...
jeffersonian000 Posted June 2, 2012 Share Posted June 2, 2012 Pretty sure this has been a standard tactic for PT units since the codex first came out. The only know limit to Shunt movement is they can't use it for a Scout Move (FAQ). SJ Link to comment Share on other sites More sharing options...
