When should I flock the bases?
It's all personal preference and based on what kind of bassing materials you're using and the type of varnish and only you can make the final call.
WOrd of advice, be careful with spraying anthing over static grass. Best case you'll get the grass clumped to gether with little beads here and there, worst case the will be some loose static grass now scattered over the mini and stuck in the varnish.
