Storm Eagle side doors
I am planning on getting two Storm Eagles and had an idea for a conversion. For the side doors I would add magnets so that I could attach either the lascannon sponsons from a Land Raider and maybe a set of predator sponsons if I felt like it for the heavy bolters. Do either sponsons fit the side doors?
https://bolterandchainsword.com/topic/253612-storm-eagle-side-doors/
I'm only making an educated guess* here I'm afraid but I would say that predator sponsons will fit without a problem as the Storm Eagle is based on the Storm Raven which uses Rhino sized doors. The Land Raider sponsons however will be too large and would require some conversion work to get a flush fit.
*I have a Storm Raven that is mid-painting just now which I took the doors from to use on a project with a Rhino and they were a perfect fit.
hope this helps
James
Land Raiders sure the same size side doors as a Rhino.
Huh? if you meant "use" you're wrong. LR doors will not fit a RHino and Rhino doors will not fit a LR. So by extention LR spoonson will not fit a vehicle that uses Rhino doors, Pred sponsons on the other hand are slightly different, they will fit a rhino chassi in place of the door and on a LR they fit within the inner opening not by taking the place of the ussual door.
