Jolemai Posted June 7, 2012 Share Posted June 7, 2012 Sorry for another question on Vindicare ammunition, but I felt it better to make a new post rather than dabble in thread necromancy. I would like you opinion on the following: An Ork Mek with a Kustom Force Field provides an invulnerable save to anything Orkish inside 6 inches. If a Vindicare used his Shield Breaker round on a model being protected by this, would the invulnerable save be negated on this model only or would I have to shoot the Mek to remove the force field from surrounding models? Link to comment Share on other sites More sharing options...
dswanick Posted June 7, 2012 Share Posted June 7, 2012 Sorry for another question on Vindicare ammunition, but I felt it better to make a new post rather than dabble in thread necromancy. I would like you opinion on the following: An Ork Mek with a Kustom Force Field provides an invulnerable save to anything Orkish inside 6 inches. If a Vindicare used his Shield Breaker round on a model being protected by this, would the invulnerable save be negated on this model only or would I have to shoot the Mek to remove the force field from surrounding models? The Shield Breaker provides no benefit against the KFF, which provides a Cover save not an Invulnerable save. Kustom Force Field: Meks will build or scavenge powerful force field projectors with which to protect their warty hides. A kustom force field gives all units within 6" of the Mek a cover save of 5+. Vehides within 6'" are treated as being obscured targets. The force field has no effect in an assault. Shield-Breaker: When a wound from this round is allocated to a model, that model loses any invulnerable saves granted by items of wargear immediately, and for the rest of the battle. Remaining saves (if any) can then be taken. Link to comment Share on other sites More sharing options...
Jolemai Posted June 7, 2012 Author Share Posted June 7, 2012 Thanks for your reply :P Link to comment Share on other sites More sharing options...
