Rune_Priest_Rhapsody Posted June 8, 2012 Share Posted June 8, 2012 This just screams conversion possibilities to me. I love the poses on both models, and having another standard bearer option is always nice. I will be purchasing one of these!! http://www.forgeworld.co.uk/New_Stuff/SPAC...OMMAND_SET.html End of Line Link to comment https://bolterandchainsword.com/topic/253866-mkiv-command-set/ Share on other sites More sharing options...
Kassill Posted June 8, 2012 Share Posted June 8, 2012 Not very wolfy, but I still love them and MKIV just..... :) Link to comment https://bolterandchainsword.com/topic/253866-mkiv-command-set/#findComment-3080897 Share on other sites More sharing options...
Russ Brother 92 Posted June 8, 2012 Share Posted June 8, 2012 Indeed - I can see myself adding these to my army and potentially doing up a nice if rather blue or yellow diorama with these guys and some of the other Mark IV guys :) Link to comment https://bolterandchainsword.com/topic/253866-mkiv-command-set/#findComment-3080930 Share on other sites More sharing options...
Rune_Priest_Rhapsody Posted June 8, 2012 Author Share Posted June 8, 2012 I'm thinking the small crest will get covered with the wolf skull triangle from the upgrade sprue, head swap him with a more suitable wolf lord head, swap his pack with the wolf head pack also from the upgrade sprue, frost axe the power sword, and dangle a few wolf tails off of his armor. If the helmet under is are is easily removed, I'll swap that out as well!! I love the chunky look of the Maxumus armor for some reason. It might be because it looks slightly similar to traditional suits of armor form the medieval times. And the 'snout' helmets are really striking. If this arrives in time (won't ship out intil the end of the month... :)) , I might have to ETL vow it!! End of Line Link to comment https://bolterandchainsword.com/topic/253866-mkiv-command-set/#findComment-3080938 Share on other sites More sharing options...
Russ Brother 92 Posted June 8, 2012 Share Posted June 8, 2012 I was thinking of getting some of the brass etched bits - if you look at the new minotaurs etchings, they have them placed on those two command models and the look brilliant, so rather than remove too many things I'd put some etchings on these guys, little runes on the legs etc. ;) Link to comment https://bolterandchainsword.com/topic/253866-mkiv-command-set/#findComment-3081029 Share on other sites More sharing options...
arizonajirt Posted June 11, 2012 Share Posted June 11, 2012 they are very nice. I just hope they dont turn out like the new apothecaries. when i got them in the mail, the legs torso and head were all 1 piece, like finecast models. and even came on a similar frame from the injection mold. but either way ill be ordering a set Link to comment https://bolterandchainsword.com/topic/253866-mkiv-command-set/#findComment-3083116 Share on other sites More sharing options...
Rune_Priest_Rhapsody Posted June 11, 2012 Author Share Posted June 11, 2012 I didn't think the Apoth kit was one big chunk!! I hope that this kit is not like that otherwise all of my converting will take even more time and look even worse... Good to know however, thanks arizonajirt. End of Line Link to comment https://bolterandchainsword.com/topic/253866-mkiv-command-set/#findComment-3083148 Share on other sites More sharing options...
Phoros Posted June 11, 2012 Share Posted June 11, 2012 It calls them "multi-part", and the pictures in the Minotaurs Brass Etching entry are posed at least slightly differently. Link to comment https://bolterandchainsword.com/topic/253866-mkiv-command-set/#findComment-3083153 Share on other sites More sharing options...
arizonajirt Posted June 13, 2012 Share Posted June 13, 2012 on Forge Worlds Facebook page someone asked if they came with extra bits and this is what they said about the models: " Each model is a single-part body, separate head, left and right arms, and a separate shoulder pad (the cloak of each is attached to the relevant arm)" Link to comment https://bolterandchainsword.com/topic/253866-mkiv-command-set/#findComment-3085131 Share on other sites More sharing options...
