Midnightmare Posted June 12, 2012 Share Posted June 12, 2012 Quick question; does a Dread have to disembark from the rear (ie where the magna/winch is) or can he be placed anywhere within 2" of the Ravens base? Cheers Link to comment https://bolterandchainsword.com/topic/254056-dreads-and-stormravens/ Share on other sites More sharing options...
dswanick Posted June 12, 2012 Share Posted June 12, 2012 Do you own the Codex? The Codex is your friend. For the purposes of claiming/contesting objectives and embarking/disembarking from a Stormraven, measure to and from its base. Link to comment https://bolterandchainsword.com/topic/254056-dreads-and-stormravens/#findComment-3083608 Share on other sites More sharing options...
Midnightmare Posted June 12, 2012 Author Share Posted June 12, 2012 Ha ha just unsure if it had to be from the back as it doesn't say! Link to comment https://bolterandchainsword.com/topic/254056-dreads-and-stormravens/#findComment-3083619 Share on other sites More sharing options...
DominicJ Posted June 16, 2012 Share Posted June 16, 2012 2" from the access point, is where models disembark. The Dreadie access point is the rear, therefore, the dreadie disambarks within two inches of the rear Link to comment https://bolterandchainsword.com/topic/254056-dreads-and-stormravens/#findComment-3087071 Share on other sites More sharing options...
Murcielago Posted June 16, 2012 Share Posted June 16, 2012 2" from the access point, is where models disembark.The Dreadie access point is the rear, therefore, the dreadie disambarks within two inches of the rear Refer to the above post with the quote from your codex Link to comment https://bolterandchainsword.com/topic/254056-dreads-and-stormravens/#findComment-3087076 Share on other sites More sharing options...
Drunken Angel Posted June 16, 2012 Share Posted June 16, 2012 And of course you can always pivot the Raven 90 degrees on its movement phase if that helps. Link to comment https://bolterandchainsword.com/topic/254056-dreads-and-stormravens/#findComment-3087079 Share on other sites More sharing options...
dswanick Posted June 16, 2012 Share Posted June 16, 2012 2" from the access point, is where models disembark.The Dreadie access point is the rear, therefore, the dreadie disambarks within two inches of the rear Do you own the Codex? The Codex is your friend. For the purposes of claiming/contesting objectives and embarking/disembarking from a Stormraven, measure to and from its base. "For the purposes of"..."disembarking from a Stormraven"..."measure"..."from its base"...full stop. No mention of access points, and no need to use a particular portion of the base. The front is as valid as the back. Link to comment https://bolterandchainsword.com/topic/254056-dreads-and-stormravens/#findComment-3087080 Share on other sites More sharing options...
SevenExxes Posted June 16, 2012 Share Posted June 16, 2012 This has been said before but, check page 38 C:BA Link to comment https://bolterandchainsword.com/topic/254056-dreads-and-stormravens/#findComment-3087085 Share on other sites More sharing options...
