Olgerth Istaarn Posted June 14, 2012 Share Posted June 14, 2012 Just what it says on the tin. I want to put Dozer Blades on my Rhinos, but the ones I ordered from a certain Polish company came in warped and crappy in general. Lesson learned. I want to try fitting IG Chimera dozer blades to Rhinos, but will they fit? Link to comment https://bolterandchainsword.com/topic/254162-chimera-dozer-blade-rhino/ Share on other sites More sharing options...
elmo Posted June 14, 2012 Share Posted June 14, 2012 I am in the middle of a similar thing and the ones I have fit with only a little modification. Link to comment https://bolterandchainsword.com/topic/254162-chimera-dozer-blade-rhino/#findComment-3085562 Share on other sites More sharing options...
Grotsmasha Posted June 14, 2012 Share Posted June 14, 2012 Is the Chimera and Leman Russ one the same? I've used the LR one, pics when I get home. Cheers, Jono Link to comment https://bolterandchainsword.com/topic/254162-chimera-dozer-blade-rhino/#findComment-3085586 Share on other sites More sharing options...
ShinyRhino Posted June 14, 2012 Share Posted June 14, 2012 I know for a fact that the ones on the IG Vehicle Accessory Sprue will fit, just barely. I've test-fit them a couple times under my Rhinos, and am planning to one day magnetize them under the chassis. They're the best looking dozers you can get outside of Forgeworld. Did you contact said Polish company and see about replacements? Link to comment https://bolterandchainsword.com/topic/254162-chimera-dozer-blade-rhino/#findComment-3085596 Share on other sites More sharing options...
HellHunter Posted June 14, 2012 Share Posted June 14, 2012 Yeah they fit just fine. They stick out a little farther than on a Russ and you'll more or less need to eyeball it to center it, but other than that I've used them on my rhinos and predators just fine. Yeah they fit just fine. They stick out a little farther than on a Russ and you'll more or less need to eyeball it to center it, but other than that I've used them on my rhinos and predators just fine. Link to comment https://bolterandchainsword.com/topic/254162-chimera-dozer-blade-rhino/#findComment-3085597 Share on other sites More sharing options...
Olgerth Istaarn Posted June 14, 2012 Author Share Posted June 14, 2012 Cool, thank you. I'll try it out. Link to comment https://bolterandchainsword.com/topic/254162-chimera-dozer-blade-rhino/#findComment-3085634 Share on other sites More sharing options...
Gurth Posted June 14, 2012 Share Posted June 14, 2012 Yeah they fit just fine. They stick out a little farther than on a Russ and you'll more or less need to eyeball it to center it, but other than that I've used them on my rhinos and predators just fine. Yeah they fit just fine. They stick out a little farther than on a Russ and you'll more or less need to eyeball it to center it, but other than that I've used them on my rhinos and predators just fine. Better look out, both barrels were loaded. Link to comment https://bolterandchainsword.com/topic/254162-chimera-dozer-blade-rhino/#findComment-3085669 Share on other sites More sharing options...
