Cyrox Posted June 15, 2012 Share Posted June 15, 2012 I'm looking to outfit one of my Marines with a decent heavy flamer - does anyone know of the best components or donor model i can use? The Legion of the Damned Heavy flamer dude in Finecast looks like he could be suitable? Suggestions would be most welcome ;) Thanks Link to comment https://bolterandchainsword.com/topic/254193-best-heavy-flamer-model/ Share on other sites More sharing options...
Raphiel Posted June 15, 2012 Share Posted June 15, 2012 I use the Heavy Flamer arm from the Terminator box. With a bit of work it will fit nicely on a power armour marine. Link to comment https://bolterandchainsword.com/topic/254193-best-heavy-flamer-model/#findComment-3086232 Share on other sites More sharing options...
xAegisx Posted June 15, 2012 Share Posted June 15, 2012 i used the ones from the catachan command squad box for mine. http://i.ebayimg.com/00/$(KGrHqR,!hoE0h%20uGydKBN(PcV5Kvg~~_35.JPG just have to shave the hand off the grip, but your marines hand was going there anyway. :D Link to comment https://bolterandchainsword.com/topic/254193-best-heavy-flamer-model/#findComment-3086240 Share on other sites More sharing options...
Tellos05 Posted June 15, 2012 Share Posted June 15, 2012 You could use the mutli melta from the devs, cut the barrels off, and stick flamer barrels on. Link to comment https://bolterandchainsword.com/topic/254193-best-heavy-flamer-model/#findComment-3086285 Share on other sites More sharing options...
lhg033 Posted June 15, 2012 Share Posted June 15, 2012 seconding Raphiel - the terminator one is a good choice and easy/cheap to get hold of - find a local deathiwng player and they will have loads spare (i must have double digits of them in my bits box that i keep swearing will be usefull one day) or a bits site. another option i've seen done is counts as heavy flamer with a model wielding two standard flamers but this can be open to your opponents permission if they are picky Link to comment https://bolterandchainsword.com/topic/254193-best-heavy-flamer-model/#findComment-3086290 Share on other sites More sharing options...
adamv6 Posted June 15, 2012 Share Posted June 15, 2012 The Grey Knights Incinerator looks great on normal Space Marines. I converted one for a Saladmunchers player at our club. GS the lettering, and remove the inquisition symbol on the tank and it looks fantastic. Link to comment https://bolterandchainsword.com/topic/254193-best-heavy-flamer-model/#findComment-3086328 Share on other sites More sharing options...
chromedog Posted June 15, 2012 Share Posted June 15, 2012 The "sternguard" one in the codex was a terminator one cut off at the elbow and grafted to a marine arm. That's the simplest one. Link to comment https://bolterandchainsword.com/topic/254193-best-heavy-flamer-model/#findComment-3086347 Share on other sites More sharing options...
Cyrox Posted June 15, 2012 Author Share Posted June 15, 2012 D'oh, i didn't even think of the Termintaor one, i have two of those! Thanks all - will explore all the suggestions - cheers! :cuss Link to comment https://bolterandchainsword.com/topic/254193-best-heavy-flamer-model/#findComment-3086373 Share on other sites More sharing options...
NoxinWolves Posted June 16, 2012 Share Posted June 16, 2012 I'm planning on using the grey knights psilencer with the incinerator. Link to comment https://bolterandchainsword.com/topic/254193-best-heavy-flamer-model/#findComment-3087213 Share on other sites More sharing options...
Lestat Posted June 16, 2012 Share Posted June 16, 2012 I used the GK incinerator on my Sternguard squads - works quite well with minimal conversion work (just need to shave off the =I= on the fuel canister) Link to comment https://bolterandchainsword.com/topic/254193-best-heavy-flamer-model/#findComment-3087344 Share on other sites More sharing options...
