Old Terminator models
WyrdWolf
So, I just paid 30 bucks on ebay for some terminators. Turns out they ended up being the old school terminators taht are the size of power armor space marines. Do any of you guys utilize these terminators on the 40mm bases mixed in with the new terminators or what? I feel like they'll seem a little out of place. Opinions?
https://bolterandchainsword.com/topic/254498-old-terminator-models/
Frankly, I run them on their old 25mm bases- AS RUSS INTENDED.
Seriously though, the rules state 'put it on the base it came with' wich means old TDA goes on 25mm, and new TDA goes on 40mm. Theres ups and downs to both situations.
And while I suppose they could look out of place Ive never had anyone comment other than to say it was cool to see the old guys out for a walk.
Though I do keep a spare set of 40mms, just in case my opponent makes a deal of it- as I said it matters little to me and Id rather have a fun game than argue about GWs rules.
Rules that are about to change again in 9 days anyway, too; the rules for bases have been different in every version of the game so far, so you might as well wait just a bit to see what happens. Putting them on the larger bases will help them look right, and if you elevate them just a tad on the base that works, too. I've got several squads of the original metal WGT models, and they aren't all that much smaller than the current plastics, certainly not to the point of being similar to power armour size, so you're definitely exaggerating a bit there.
Valerian
I have loads of those old termies and tend to mix and match my squads.
I have them on their 25mm base on top of a 40mm. That way they *are* on the base they came with, they are a bit taller to go with the modern termies and everyone has the same base size which gives my squads a more coherent look...
As Grey Mage said, it's actually a blessing in disguise to have the option to use either base as it came with the smaller ones (easier to fit and hide, more vulnerable to templates however).
I use the old models, just put on new bases. I find they have character and usually get some of the old players all excited like a little giddy school girl.
It's your models, do with it as you want; as long as you're not breaking the rules (which you aren't) have fun with the game. If someone makes a big stink about the model base size, educate them on the rules, if they're still making a fuss, don't play with them, it's quite simple.
i use 1 old terminator on a 40 mm base but i almost always use him as a wolf lord or a wolfguard battle leader and i figured why wouldn't an HQ have the oldest set of armor and the most ornate in my case as i added some stuff to it to make it look cooler. but all i did was as he was on the smaller base all ready i simply took the short cut of gluing the old base to the 40mm base and he stands just a tall as the rest of them that way
I decided to actually pull out a few models for a comparison:
As you can see, the new plastic Terminator model does tower over the others, and is quite impressive. The actual model height on the plastic Power Armoured Space Wolf looks to be about the same as on the old metal 2nd Edition-era (early '90s) Terminator, but the head placement on the old metal model is somewhat lower.
Anyway, with a simple 40mm base upgrade for your old metal models, you can prevent them from looking too out of place in a "modern" Space Wolves army. That being said, I do very much prefer plastics to metal models, and would recommend that the OP try to get his hands on the "new" WGT sprues (from eBay or a cheap online retailer) and go from there.
Valerian
If you wanted to update the OOP tda models, I would cut the model above the belt and raise the torso a bit.. maybe the width of 1-2 sheets of plasticard (what is that, 2mm?). Next, I'd lower the shoulders slightly. Obviously there's lots of ways to update them, but this would be the quickest way I think I'd go about it.
I've been thinking of doing the same type of conversion, myself. By adding a bit of space in the torso, and slightly shifting the shoulders lower it should be fairly easy to making the old terminators a bit closer to the new ones.
My problem is that I hate cutting into OOP models, preferring to keep them as some sort of vintage timecapsule, so I don't know that I'd ever do this myself and instead just get the newer tda models.
The current RPTDA on the GW site would be the exception for me, since it's not OOP yet, but still an extremely outdated model anatomically.
Also, has anyone else noticed the head size between older tda and the newest? Arjac, for example, has a very proportionate head for TDA compared to say Njal or the current plastic WG which are better than the OOP tda... maybe another 5 years and tda models may actually look like they have a torso and neck.
thanks for all the replies guys. I just got my second set of oop marines in and they all came with 40mm bases, so I'm thinking I might just suck it up and buy 7 or so 40mm bases to put the other terminators on. As far as adding newer plastic terminator arms to them, does it look decently proportional? Because currently most of the terminators I got have power fists, and chainfists, and while i'll probably keep a couple of those, I'm looking more towards power/frost weapon, and lightning claw spam. Speaking of which what would everyone recommend as a set up for a logan wing army? I was thinking lots of cyclones (I currently have 5) throughout the army, with a heavy bit of lightning claws and maybe a TH/SS and a PF or CF in a squad with a wolf priest in terminator armor. And then running a couple of TH/SS termies along with frost weapons in a group with Logan. I have a total of about 30 terminator models at this point, so I shouldn't be lacking in model count.
