greatcrusade08 Posted June 23, 2012 Share Posted June 23, 2012 Quick Q. can the necron chronometron be used to re-roll one of the leadership dice? Link to comment https://bolterandchainsword.com/topic/254589-chronometron-question/ Share on other sites More sharing options...
Grey Mage Posted June 23, 2012 Share Posted June 23, 2012 No. Because the 2d6 is a single roll- you rolled 2d6, not two 1d6s. Just like with the scatter dice its all a single roll, and so by the language in C:Necrons you cant touch leadership tests. Link to comment https://bolterandchainsword.com/topic/254589-chronometron-question/#findComment-3093343 Share on other sites More sharing options...
dswanick Posted June 23, 2012 Share Posted June 23, 2012 Quick Q.can the necron chronometron be used to re-roll one of the leadership dice? No. Because the 2d6 is a single roll- you rolled 2d6, not two 1d6s. Just like with the scatter dice its all a single roll, and so by the language in C:Necrons you cant touch leadership tests. Agreed : A Necron with a chronometron can re-roll one of his D6 rolls each phase. If the bearer is in a unit, this ability can be used to instead re-roll one of the unit's D6 rolls each phase. and while it is not directly relevant : Q. Does a Wolf Standard allow Leadership test results to be re-rolled? (p62)A. No, as it is impossible to roll a ‘1’ on 2D6 – when making a 2D6 result you must count both dice as a single roll, not address them individually. I could find nothing more directly related (BRB, BRB FAQ, C:N FAQ). But I think that it shows that GW considers a Ld 2D6 to be a single dice roll, just as Grey Mage's above example of Scatter Dice (2D6 + Scatter). Link to comment https://bolterandchainsword.com/topic/254589-chronometron-question/#findComment-3093352 Share on other sites More sharing options...
Grey Mage Posted June 23, 2012 Share Posted June 23, 2012 Pg. 2 of the BRB states: "If you re-roll a 2D6 or 3D6 roll, you must re-roll all of the dice and not just some of them, unless the rule granting you the re-roll explicitly specifies otherwise." Link to comment https://bolterandchainsword.com/topic/254589-chronometron-question/#findComment-3093362 Share on other sites More sharing options...
dswanick Posted June 23, 2012 Share Posted June 23, 2012 Thanks, knew it was in there somewhere - but darned if I could find it... Link to comment https://bolterandchainsword.com/topic/254589-chronometron-question/#findComment-3093417 Share on other sites More sharing options...
Grey Mage Posted June 23, 2012 Share Posted June 23, 2012 Yeah, its the simple ones that get ya sometimes. I remember searching for a week for the list of unit types when someone once tried to tell me that a jetbike was different than a bike in all respects, just shared some rules.... Link to comment https://bolterandchainsword.com/topic/254589-chronometron-question/#findComment-3093496 Share on other sites More sharing options...
greatcrusade08 Posted June 24, 2012 Author Share Posted June 24, 2012 interesting, thanks fellas. facing imotekh and chronometron (with scarab farm) was tough, but they should have died turn one with that Ld thing.. oh well ill know for next time Link to comment https://bolterandchainsword.com/topic/254589-chronometron-question/#findComment-3093807 Share on other sites More sharing options...
