The Relic
So in mission 6 "The Relic" the relic may only move 6" a turn, even when in a transport, but can be carried by any model.
In addition, it is dropped if the model falls back or is removed as a casualty.
However, this is not the only ways models can move. What about those units that are capable of unusual redeployments such as Gate of Infinity, Swooping Hawks via Skyleap, and mawlocs reburrowing?
While it seems reasonable to me to simply disallow these moves while the model continues to hold the relic, there doesnt appear to be a RAW answer for it.
https://bolterandchainsword.com/topic/255263-the-relic/
It's answered, if you but read a little more :lol:.
"If it [the model carrying the relic] is forced to do so [move more than 6"], the Relic is immediately dropped."
Besides, it can only be picked up by a scoring unit, which cuts out Mawlocs and Swooping Hawks from the picture. Since the Gate was more or less defined as movement, I figure it'd make them drop it too.
https://bolterandchainsword.com/topic/255263-the-relic/#findComment-3105857
It's answered, if you but read a little more :blink:.
There's an argument to be made that you get to take it if using Gate takes you 6" or less in terms of distance. Would be a bit cheeky to try it though, and its not something I intend to do. What about scoring Jetbikes...could they in theory turbo-boost 6" (and the same for Ravenwing and Codex: SM bikers with a bike captain), and then get their 2d6" assault phase move, which says "up to 2d6", so choosing to cap it at 6? I realise that this is of no benefit to us, but it might if we play against pointy-headed space elves and have to try and pinch it back. Bike armies look like they could move the relic 12" in a turn, in addition to being able to get to it on turn 1, so getting there first and being back behind the rest of the army before the opponent has had a turn might make it a real uphill battle for them.
https://bolterandchainsword.com/topic/255263-the-relic/#findComment-3106314
Yes indeed!
And yes, the Jetbike bump is "up to 2D6 inches" in the assault phase. This would allow them to rocket up on the first turn and get it, turboboost for 6" back toward their lines during the shooting phase (wooo! :)), and then bump again up to 6" during the assault phase, as the Relic can only move up to 6" per phase.
https://bolterandchainsword.com/topic/255263-the-relic/#findComment-3106366
  • 2 months later...
As far as I can tell, the IC can pick it up if it is in a scoring unit. Yes. If the IC leaves that unit it does not appear that it must drop the relic in RAW. The relic remains with the model that picks it up until it is dropped. The rules then go on to list the ways the relic can be dropped. Leaving a scoring unit is not among them.
As far as dropping and picking it up, it can only be seized at the end of the movement phase so if it is dropped sometime before that, sure, you can drop and pick it up on the same turn. The relic moves with the model that has control of it so picking it up and then "dropping" it behind you where another model picks it up .... etc ... not allowed since no movement can happen after the end of the phase. It may be possible to turbo-boost like mentioned above and thus move the relic in a later phase but once it is dropped, it remains where it is until the end of the next movement phase. I think it important to say this again, the relic moves with the model that has seized it. It is not physically picked up from the table. If you want to spin the relic around to the other side of the model you will have to move the model in order to move the relic. It is also important to note that the relic can not move over 6". The model in control can move more than this as long as it stays in base contact and the relic only moves 6" or less.
[edited to fix some pronoun confusion]
https://bolterandchainsword.com/topic/255263-the-relic/#findComment-3178518
Yes indeed!
And yes, the Jetbike bump is "up to 2D6 inches" in the assault phase. This would allow them to rocket up on the first turn and get it, turboboost for 6" back toward their lines during the shooting phase (wooo! :cuss), and then bump again up to 6" during the assault phase, as the Relic can only move up to 6" per phase.
Turbo-boosting Bikes move up to 12", turbo-boosting Jetbikes move up to 24" . Controlling their Bikes at such speeds takes all the riders' concentration and skill, however. Bikes and Jetbikes therefore cannot shoot, charge or execute any other voluntary action for the rest of the turn after Turbo-boosting.
Can't do anything else after turbo-boost so no assault phase moves I'm afraid. You can steal a few extra inches in the movement phase by switching the relic from one model to another, which can potentially gain you the length of two bases.
https://bolterandchainsword.com/topic/255263-the-relic/#findComment-3178699
You can steal a few extra inches in the ovement phase by switching the relic from one model to another, which can potentially gain you the length of two bases.
I am not seeing this. To sieze the relic, you move into base contact with it. At the end of the movement phase, a modle in a scoring unit can sieze control simply by saying which model "picks it up." The thing is, the relic is not physically picked up. It is not moved and can not be moved until the model that has it is able to move with it. Moving the relic is part of the movement phase because the relic moves with the model that has siezed it. If that model moves the relic to another position, then the movement phase had not actually ended when he siezed it. Therefore he does not actually have control of it to move it in the first place. But the long and short of it, the relic can not be siezed until all movement is finished so the relic itself can not be moved and still be part of the movement phase that is already completed.
Then, even if you could pick it up and pass it over to another model, that model could not pick it up until the end of the next movement phase.
https://bolterandchainsword.com/topic/255263-the-relic/#findComment-3178888
But if an IC leaves a scoring unit to join another scoring unit, for a fraction of his move, he is joined to neither (and non-scoring.) At that point, he must drop the relic (one inch away.)
If he moves into base to base with the relic, during his move, he is not a part of a scoring unit. He does not join the unit until the end of the new scoring unit's Movement phase, or until the end of the Movement phase (for scoring units that have already moved.)
The pickup of the relic is automatic at the end of the Movement phase. But the IC was not a scoring model when he "moved" next to it, and is therefor ineligible to pick it up.
If he was already a part of the scoring unit, and never left it, he could pick it up with no issue.
Edited for typo
https://bolterandchainsword.com/topic/255263-the-relic/#findComment-3179113
Yes, you can.
Turbo-boost is a general rule for all bikes. The 2d6 move is a specific rule for (Dark) Eldar jetbikes. Specifics overrule general, remember?
https://bolterandchainsword.com/topic/255263-the-relic/#findComment-3179128
I agree that this is how it SHOULD work. But ... read the rules again and point me to the line where is says that if a model is no longer scoring it must drop it.
It says you must be in a scoring unit to pick it up. It does not say you must be in a scoring unit to retain possession. It's cheesy, it's dumb and it's borked but .... leaving a scoring unit is not in the list of reasons that the relic must be dropped.
I think there is a better case in arguing that "joined with a unit" is not the same "in the unit" so the IC is not ellegable to pick it up. Still, this is one of those things best agreed upon BEFORE starting the mission. It does not make a whole lot of difference how you play it as long as you both are playing that way from the start.
https://bolterandchainsword.com/topic/255263-the-relic/#findComment-3179160
LOL, your completely right. That is SO borked!
I try to avoid arguing during the game, and leave my arguing to these forums. GW needs to fix this.
I played a game against some Grey Knights. Their Librarian got the Precognition power while in Terminator armor. Its hard enough to wound an IC with a 2+ Look Out Sir. Add in the 2+ re-rollable save, and it becomes ridiculous. I must have fired a couple hundred bolter shots/frag bursts/missiles at him. Four tactical squads and a full ten man terminator. My precision shots would normally wound on a 1 in 6, try doing it on a 1 in 36. I did wound him once, but just couldn't get the second. I was in a position to win, if neither of us had possession. He just moved his Librarian from squad to squad, soaking up the hits.
I give my opponent kudos for thinking up a good way to win. But it just seems broken...
https://bolterandchainsword.com/topic/255263-the-relic/#findComment-3179208
Yes, you can.
As per the BGB, on page 45, "Turbo-boosting Bikes move up to 12”, Turbo-boosting Jetbikes move up to 24”. Controlling their Bikes at such speeds takes all the riders’ concentration and skill, however. Bikes and Jetbikes therefore cannot shoot, charge or execute any other voluntary action for the rest of the turn after Turbo-boosting."
https://bolterandchainsword.com/topic/255263-the-relic/#findComment-3179631
