Need some magnet advice
I have a set of 3mm x .5mm magnets here which I believe are n45 grade and I'm looking to restock on them because I'm rapidly running out. They're extremely useful, they'll hold a space marine arm to the torso with enough strength that you can pick the model up by the arm, and they're fine for torso-to-leg bonds as well.
Unfortunately, I can't for the life of me find any n45 magnets of the right size, so my questions are:
Will n40 be significantly weaker - enough to cause problems?
Will a thinner magnet of a higher grade (n50 3mm x 1mm) do the same job?
I'm reasonably new to magnets, so I'm still learning.
https://bolterandchainsword.com/topic/255561-need-some-magnet-advice/
As an update, I ended up ordering both, and the N40 1x1.5mm and the N50 1x1mm seem to have the exact same pull strength as far as I can determine (basic pulling and fitting tests) so in case anyone else has this question in the future, they're interchangeable :lol:
