6th Edition game experiences
You get all three.
@Khine - why do you say you should take a bolter as secondary for charges? It is effectively the same as a bolt pistol.
Sorry i should have been a bit more clear. Being charged, so that they each get 2 bolter shots each for overwatch.
Pretty sure you cannot use rapid fire for snap shots.
What is the page number where it says this?
You get all three.
Can't see a place where is says you can't so please let us know if you can prove this - snap shots can fire multiple shots but at BS1, and overwatch is principally this with a few specific exceptions so I can't see why rapid fire wouldn't work at BS1 for overwatch. Not mentioned in either section for as an exception so likely boltgun wins over boltpistol for overwatch... Its another reason why cheap multi-shot weapons will be on the rise in 6th, such as the humble heavy bolter.
Assuming I have been playing this correctly, it makes you swallow hard before charging a block of 30 imperial guardsmen with lasguns (who will likely hit you 10 times) or a big heavy weapon totting squad - with some good dice rolls you can lose quite alot on the way in sometimes.
Sry guys but where does it says we can take power axe in GH unit?
Codex Space Wolves, page 89, which is the Grey Hunters Pack unit entry:
One Grey Hunter may replace his close combat weapon with on of the following:
-Power weapon..... ?? points
Valerian
