Furious Charge adds +1 to its Strength characteristic until the end of that phase. Unless it made a "disordered charge", then it can't receive the benefit.
Not sure what a disordered charge is. Something about multi-charging I think.
EDIT: since I got ninja'd I might as well look up disordered charge...
A disordered charge is a multi-charge, and therefore you get no +1 attack bonus when you charge. When you charge you have to declare primary and secondary targets, and the primary target is what you measure to for charging.
EDIT again, because I reread the part about seeing a target (it still apparently applies to secondary targets)
so does that mean if you deliberatly mix 2 squads together then you can deny your opponent his extra attack? 2 combat squads seperated and mixed in at all times. interesting.
Doesn't look like it - declaring a secondary charge target is optional, you could just charge one or other of the combat squads if you wanted.
