dadieau Posted July 12, 2012 Share Posted July 12, 2012 So, with Prescience can I re-roll the Scatter die (or rather all of the dice with the scatter die)? Can I target a vehicle with Prescience (or squadron of vehicles)? Link to comment Share on other sites More sharing options...
Zzo Posted July 12, 2012 Share Posted July 12, 2012 Yes, you may re-roll the scatter die, but you must also re-roll the other dice as well. And I believe you can target a vehicle with it, as the power says you may target any friendly unit. Link to comment Share on other sites More sharing options...
Gentlemanloser Posted July 12, 2012 Share Posted July 12, 2012 Didn't want to make a new Topic, but if this is considered highjacking, I will. <_< How does Prescience interact with Template Weapons? Template Weapons only reroll wounds if thier Twin Linked, and Prescience doesn't make your weapons twin-linked, only allows you to reroll hits, much like a beefed up Master Crafting. So currently, by RAW, Prescience has no effect on Template weapons? I'd assume the RAI would be to in essence make them twin-linked. But, well, the rules could be clearer/tighter. :P Link to comment Share on other sites More sharing options...
DarkGuard Posted July 12, 2012 Share Posted July 12, 2012 Twin-linked isn't re-roll to hit. Rather it's a rule that uses re-roll to hit, that then has it's own section on templates re-rolling to wound. Therefore, RAW, and IMO, RAI, templates don't re-roll to wound with any re-roll to hit abilities. Twin-linked is different. Link to comment Share on other sites More sharing options...
