Shadow14_8 Posted July 15, 2012 Share Posted July 15, 2012 I recently started Grey Knights after playing Space Marines (Salamanders) for about 5 yrs. I recently purchased the following: 20 X terminators 10 X PA GK 1 X DKnight Curious what your thoughts are on using terminators as Paladins and vice a versa depending on the game. The only visible difference I can see in the codex is 4 Psycannons compared to 2 (10 man squad) and their heraldry shield on their shoulder pads are a little fancier. The only reason I ask is like many of you Im a gamer on a budget and may not be able to add a ton of terminators for awhile. My game group is friendly and it wont be a problem and the few tourneys I play in seem pretty laid back. Any advice is appreciated on any of my purchase thanks for the help. Link to comment https://bolterandchainsword.com/topic/256606-paladins-and-termies-interchangable/ Share on other sites More sharing options...
nurglez Posted July 15, 2012 Share Posted July 15, 2012 I have paladins. When 6th was released there was a 500 point tourny at my local gw store, so I made 10 gk Termies from my 15man pally squad. I didn't put banners or shields on my paladins, they are pretty bare of extra equipment. As long as you can tell, and its easy to spot the difference I wouldn't have any issue. If you are using models exactly the same for paladins and terminators it could get confusing, so make something simple that is easy to spot, like blue tac shields onto the paladins. Link to comment https://bolterandchainsword.com/topic/256606-paladins-and-termies-interchangable/#findComment-3122219 Share on other sites More sharing options...
Inquisitor Fox Posted July 15, 2012 Share Posted July 15, 2012 I plan on taking my pewter Terminators and adding the "back banner" bits to call them Paladins. I plan on Terminators without the "back banner" bits being Terminators. In that sense, if you make the "back banner" bits interchangable somehow with pins or something, and just say that if it's got a banner it's a Paladin, that seems pretty simple :) Link to comment https://bolterandchainsword.com/topic/256606-paladins-and-termies-interchangable/#findComment-3122223 Share on other sites More sharing options...
Shadow14_8 Posted July 15, 2012 Author Share Posted July 15, 2012 By back banner you mean the small heraldry shield on shoulder pads right? ill definiely do the blue tack idea if thats all it takes then. Thanks for the replys. Link to comment https://bolterandchainsword.com/topic/256606-paladins-and-termies-interchangable/#findComment-3122234 Share on other sites More sharing options...
Inquisitor Fox Posted July 15, 2012 Share Posted July 15, 2012 I meant the little poles with the books and doodads on them like these ;) The heraldry plate / besegew (although it's not circular) I use on all my Terminators with personalized heraldry. Link to comment https://bolterandchainsword.com/topic/256606-paladins-and-termies-interchangable/#findComment-3122241 Share on other sites More sharing options...
Shadow14_8 Posted July 15, 2012 Author Share Posted July 15, 2012 Genius :D Thanks Im gonna steal that..... Link to comment https://bolterandchainsword.com/topic/256606-paladins-and-termies-interchangable/#findComment-3122318 Share on other sites More sharing options...
Stormshadow Posted July 16, 2012 Share Posted July 16, 2012 I’ve assembled all may new (plastic) Terminators as Paladins with the back banners. But I mix them up with my old (metal) Terminators. To keep it simple I never run units of Terminators together with units of paladins. Ether they are all terminators or all Paladins, so there is never any confusion :rolleyes:. Link to comment https://bolterandchainsword.com/topic/256606-paladins-and-termies-interchangable/#findComment-3122803 Share on other sites More sharing options...
Zeratil Posted July 16, 2012 Share Posted July 16, 2012 There are two different helmets for paladins and terminators if you look at the pictures in the codex and the assembly instructions, and paladins are depicted as having the back accessories. However it makes very little difference so long as your opponent is clear on what he's facing (so if you run both it's polite to make it obvious which squad is which). Link to comment https://bolterandchainsword.com/topic/256606-paladins-and-termies-interchangable/#findComment-3122910 Share on other sites More sharing options...
nurglez Posted July 16, 2012 Share Posted July 16, 2012 Aye, I used the terminator helms for my paladins, but as I only use paladins, no one has commented on them not being paladins (even with my own design of psycannon's, no back banners or extra equipment like grenades/pouches). Link to comment https://bolterandchainsword.com/topic/256606-paladins-and-termies-interchangable/#findComment-3123129 Share on other sites More sharing options...
DarthOvious Posted July 16, 2012 Share Posted July 16, 2012 I use my Paladins and Terminators interchangably. I've not had any complaints yet. Just let your opponents know what squads are paladins & what squads are terminators. Link to comment https://bolterandchainsword.com/topic/256606-paladins-and-termies-interchangable/#findComment-3123148 Share on other sites More sharing options...
Reclusiarch Darius Posted July 17, 2012 Share Posted July 17, 2012 Yeah, so long as which one is which is clearly marked (a color line on the bases works well), most people won't complain. They just know when you throw down a TDA Knight blob, you're bringing the pain :cuss Link to comment https://bolterandchainsword.com/topic/256606-paladins-and-termies-interchangable/#findComment-3123903 Share on other sites More sharing options...
Shadow14_8 Posted July 17, 2012 Author Share Posted July 17, 2012 I think Ill make up 10 "Paladins" and 10 terminators with the assumption that I can interchange them as needed. The people I play with around here wont care as long as they know what they are Im guessing. Thanks for the help. Link to comment https://bolterandchainsword.com/topic/256606-paladins-and-termies-interchangable/#findComment-3124347 Share on other sites More sharing options...
Reclusiarch Darius Posted July 17, 2012 Share Posted July 17, 2012 Just be careful how many psycannon Terminators you assemble. Paladins can field four, but regular Terminators only two (although of course, you add one back in using the TDA Inquisitor they roll with now). Also, Paladins can make swords work (depending on how you challenge), but they're wasted on normal Terminators (who only have one wound, so they might as well take a halberd and strike first). Link to comment https://bolterandchainsword.com/topic/256606-paladins-and-termies-interchangable/#findComment-3124431 Share on other sites More sharing options...
