ShinyRhino Posted July 18, 2012 Share Posted July 18, 2012 I'm working on some Scouts with cloaks, and want the cloaks to be an olive drab sort of green. When it comes to shading for these, do I want to use a brown tone or a black tone? I'm either planning to use a GW wash in the deep areas to darken the basecoat or mixing a slightly darker version of the basecoat to apply as a layer. If I go the wash route, I have Thraka Green, Devlan Mud, or Badab Black as options. Thraka Green feels like it's a little too vibrant for this purpose, though I have used it for shading reds. I'm concerned that Badab might be too dark, and that Devlan will just come off as dirty instead of shadowed. I can also just mix black or a deep brown in with the olive drab paint and layer/blend it into the shadows. Any suggestions from the color theory masters? Link to comment https://bolterandchainsword.com/topic/256871-shading-for-olive-green/ Share on other sites More sharing options...
Captain Hwarang Posted July 18, 2012 Share Posted July 18, 2012 Wouldn't say I'm a color theory master, but I'm imagining a color somewhere close to Catachan green for your olive green. Is that close? If that's what you're starting with, Thraka green will have little to no effect, as Catachan green is already darker than that wash. If you haven't started yet, I would do something like: Orkshide Shade basecoat Badab Black wash Orkhide shade layer Catachan Green Layer Gretchin green highlights Then you might even want to take it up to Rotting Flesh for an extreme highlight. If you've already got the layer of olive down, I would still use badab black instead of devlan mud, and then follow something close to those layering steps above. Hope that helps. If worse comes to worse, just try each one out on two separate guys, and re-basecoat the one you don't like. -CH Link to comment https://bolterandchainsword.com/topic/256871-shading-for-olive-green/#findComment-3125600 Share on other sites More sharing options...
winterdyne Posted July 19, 2012 Share Posted July 19, 2012 I'd shade with a black/brown/green mix. It's a good idea to glaze the shading in rather than splosh wash, you'll find this gives a cleaner finish. Typically, I base in the olive, shade down with the mix by glazing it in. Glaze back with the olive to smooth things out, then glaze on highlights (usually by adding a grey or beige to the olive). Shouldn't need more than four mixes; base, shade, highlight, then perhaps extremes. Link to comment https://bolterandchainsword.com/topic/256871-shading-for-olive-green/#findComment-3127048 Share on other sites More sharing options...
ShinyRhino Posted July 20, 2012 Author Share Posted July 20, 2012 Thanks for the feedback, guys! I'll give those ideas a go. Link to comment https://bolterandchainsword.com/topic/256871-shading-for-olive-green/#findComment-3127548 Share on other sites More sharing options...
