BattleBrotherJohn Posted July 19, 2012 Share Posted July 19, 2012 I am adding Land Speeder Tornadoes to my army list and will be taking Tornado pattern Land Speeders with double multi melta's . The kit comes with one multi melta ( to be used by the LS gunner ) but Im wondering what people would suggest ( or use themselves ) for the second MM ? I thinking of placing it were the heavy flamer / assault cannon would sit if this helps. Link to comment https://bolterandchainsword.com/topic/256974-multi-multi-meltas/ Share on other sites More sharing options...
Sons of the Forge Posted July 19, 2012 Share Posted July 19, 2012 I used to run a MM/MM landspeeder in 5th edition when I was getting back into the hobby. Obviously wasnt great in 5th but in 6th it may have its uses. To answer the question I would agree have it either slung underneath were a normal second weapon would go or like I have done for my Landspeeder Storm have the weapon were the ariel is. Shave the ariel off and then you have a flat surface to place the 2nd MM on. It looks really good to be honest. Link to comment https://bolterandchainsword.com/topic/256974-multi-multi-meltas/#findComment-3126936 Share on other sites More sharing options...
ShinyRhino Posted July 20, 2012 Share Posted July 20, 2012 Another option is to chop the flamer nozzles of an extra heavy flamer and replace them with the front of a spare multimelta bit. Problem is, the heavy flamer bits are a little expensive for some reason. Link to comment https://bolterandchainsword.com/topic/256974-multi-multi-meltas/#findComment-3127549 Share on other sites More sharing options...
