In need of modelling inspiration
I'm fielding a Grey Knight all terminator list with 22 Terminators and 2 land raiders. Hence, I bought 5 boxes of Grey Knight termies.
However, I don't every 5 of them to look similar. I'm going to do reposing and minor converts to some like removing the halberd's blade and replacing it with the falchion's or Nemesis Sword's to make a bigger halberd.
But what other converts can I do to make each Grey Knight, especially the 10 Paladins I have, look unique and different. My Space Marines have always somewhat irked me when they turn out like a whole rank of uniform badasses.
https://bolterandchainsword.com/topic/257077-in-need-of-modelling-inspiration/
First thing id say is swap in a few heads from the power armour sprues, they do not look particularly out of place or anything like that and will break it up. if you feel being fancy you could convert some heavy weapons to be using they're right arm using heavy weapons from the power armour sprue. As for paladins books and ornaments stuck on their shoulders work although if you are not using the warding staves I've found that the top of the stave works really well. you could also just paint a difference though.
(wow, i have never seen the guardians of the covenant battle cry. I am a latin scholar so all the "latin" from gw bugs me but this is particularly bad. it means "For i will agree (i will make a covenant could fit i guess) because of The Lion" and "for i venerate i will agree" lol. if you actually care it should be something more like "foederum enim et leo" and "in honorem foederum" foedus is more like treaty but the other options are pactus which is a bit informal and testamentus which is less accurate and sounds too bibley for me)
LOL at the latin. I never knew. Just copied them off a fansite.
Hmm...power armour heads...shame I don't have any left that aren't the normal SM heads with the frowny grills. But I do have some Forgeworld Iron Armour heads and they should look great.
I do like the idea of warding staves though. I think that that is the sexist weapon in the whole set by sheer aesthetics.
