Saga of the Bear or Warriorborn?
Commander Krag
What weapons is he equipped with, this would tells us a lot more so we may help you further.
Over in Toasterfrees' "TWC in 6th" thread there are a lot of helpful posts as to equipping your lord and his TWC retinue. Linky here: http://www.bolterandchainsword.com/index.p...howtopic=257000
Good luck Brother!!
End of Line
think what's more important is the unit he's in. if chances are high he'll still be in combat round 2, go for Saga of the Warrior born. if he's ,in a pack that is unlikely to leave a lot of enemies standing after 1 combatphase, he's better of with Bear, since the extra attacks from Warrior Born will be wasted, ergo 35 pts down the drain.
don't forget those extra attacks dissapear at the end of the next combatphase, to be replaced by the new amount of unsaved wounds he caused, so if he's not in combat for an assaultphase, he loses the attacks. Saga of the Warrior Born seems cool and powerfull, but ultimatly, it's extremely conditional. if you play a crossover from 40k and fantasy, and have him charge into a unit of zombies, sure, WB owns. in most other cases, it's just 35 points wasted
Plus Saga of the Bear keeps a high point model from getting squashed from a single Str 10 hit. Then if his pack makes the impact, ie kills, the unit they assault he is likely to get shot to :o by a lot of low AP weapons.
I prefer Bear in almost all situations.
End of Line
