Questions to Telion and Techmarine
1) Telion
The scout sergeant can take a teleport homer, Telion replaces the Scout Sergeant. So a scout squad with Telion can never have a teleport homer?
2) Techmarine
Does a techmarine with 4 servitors with servo-arm automatically pass his "Blessing of the Omnissiah" roll? I could not find anything, that a roll of 1 is an automatic miss in this case.
Greetings
1) Telion
That is correct.
2) Techmarine
A roll of 1 is always a miss! So a techmarine with 4 servitors doesn't pass his "Blessing of the Omnissiah" rollautomatically. Best roll is always 2+ ;)
1) Tellion cannot take a teleport homer, his gear is fixed and he has no options. (as far as i know)
2) This is tricky because of the way it is worded. Servitors technically do not lower your target number, they raise your dice roll. You always need a 5+ but each servitor adds 1 to your roll. So if you rolled a 1 and had four servitors, it would be 1+4 = 5.
In my opinion that would still be a success.
A roll of 1 is always a miss! So a techmarine with 4 servitors doesn't pass his "Blessing of the Omnissiah" rollautomatically. Best roll is always 2+ :devil:
Not quite, a roll To Hit (pg.13), to Wound (pg.14), Saves (pg.19) and a reserve roll (pg.124) all fail on a roll of 1.
The Blessing of the Omnissiah is none of these.
A roll of one does not 'always' fail, turn to page 7 in a characteristic test
...a dice roll of one is always a success.
The 'one always fails' only applies to certain rules, Blessing is not one of them.
