Warp charge allocation
Shadow14_8
Lets assume I have a unit of ten terminators and I want to use Hammerhand, that would use up their 1 Warp charge point and then I couldn't use that point to affect their Nemesis force weapons correct? Or am i missing something? and how would this affect other units also (paladins etc).
https://bolterandchainsword.com/topic/258197-warp-charge-allocation/
Well, can't recall the BRB version of Brotherhood of Psykers, so that might mention warp charges.
But for characters with PML, Codex > BRB and the codex tells you exactly how many powers someone with a PML can use.
Contraversial, as it should have been FAQed, but it wasn't.
It's a shame you're wrong.
Do you even own a 6th Ed rulebook/Codex: Grey Knights? If so, have you read them?
;), just :P...
Sorry but you're going back on my block list - I can't handle any more of this nonsense.
I own the GK dex. Sadly the BRB is back with a mate atm.
My OP was a tongue in check reference to my OR thread I made, that GM locked.
/shrug
GK Codex PML rules still > BRB Warp Charge rules. :P
Should have been FAQed, Wasn't.
Edit: Here's my OP.
http://www.bolterandchainsword.com/index.p...howtopic=256235
And it didn't seem to offend you as much then DS. ;)
Well anyway I wasnt trying to open a can of worms. My real question hasnt been answered and that is related to nemesis force weapons. They use a warp charge to operate correct? therefore hammerhand would be out that turn if you wanted instant death in the case of terminators. Is that the consensous? Paladins may be different because they are characters.
Having 1 warp charge to spend is the same as only being able to cast 1 psychic ability a turn, so its the same as it was in 5th pretty much.
Paladins could either use holocaust, hammer hand or activate their force weapons. This hasn't changed.
Strike squads could either use warp quake, hammer hand or activate their force weapons.
OP, you still need to use a warp charge to use a psychic power. PML basically gives you 1 warp charge per level. Think of the powers in the C:GK as a 1 WC power. If you are PML 3 you get 3 WC points, which you can use to cast 3 C:GK powers. OR! if you take BRB powers you can cast up to 3 WC points WORTH of powers in a turn.
Cant get that wrong no matter how you look at it
Indeed, many a champion has fallen prey to our force weapons
Minor note here, but a Nemesis Daemon Hammer hits at S8, which would ID any of the T4 infantry in the BA codex even without activating Force Weapon mode. The only model with EW in the codex is the Sanguinor. :devil:
Well if you use hammerhand, its S10! :)
This is true. ;) You don't need S10 to ID a T4 model (which is every infantry model in the BA, if I'm not mistaken...save Mephiston, who's T6). There are other circumstances...rolling +1 on Iron Arm from Biomancy makes a Librarian T5. Also, S10 sounds cool. :Elite: And makes tearing through a LR with your hands a reality.
If Gentlemanloser is going to use silly logic, then I will too.
The codex says Grey Knights can use one psychic power per level of mastery that the unit/model has. This is in regards to the powers in the codex, which do not require warp charges.
While the BRB says Grey Knights can access the Divination, Pyromancy and (Telekinesis?) disciplines, the codex makes no mention of the Grey Knights' access to these powers. Codex > BRB, so Grey Knights cannot use powers from the BRB.
To reinforce this point, the BRB disciplines require warp charges to activate. According to Gentlemanloser, Grey Knights follow their own rules that don't use warp charges at all. Being a PML3 Librarian gives you no Warp Charges, because our BoP is different. Since these powers require a resource that Gentlemanloser is certain the Grey Knights do not have, they cannot use the BRB powers at all.
(This post is made purely as a sarcastic response to Gentlemanloser and his many posts about his stance on this issue, and does not reflect my real opinions on this topic)
-Brovius
