Valkyrion Posted August 5, 2012 Share Posted August 5, 2012 I've loads of minis stuck together from back in't day that I'd like ungluing. Is there anything out there to unstick plastic glue? Link to comment https://bolterandchainsword.com/topic/258349-anything-to-remove-plastic-glue/ Share on other sites More sharing options...
dswanick Posted August 5, 2012 Share Posted August 5, 2012 If you're talking standard plastic models glued together with standard plastic glue - then no. Plastic glue works by chemically melting the two pieces of plastic together, meaning they are bound together as if they had been molded as a single piece of plastic. Link to comment https://bolterandchainsword.com/topic/258349-anything-to-remove-plastic-glue/#findComment-3141847 Share on other sites More sharing options...
Leonis Posted August 5, 2012 Share Posted August 5, 2012 I made a mistake the other day with some shoulder pads being on the wrong way round and I managed to pop them off with a green stuff modelling tool and some gentle pressure. No damage to the parts. I think the thicker plastic glue is easier to pop off as there is a seam that isn't quite bonded. Thin plastic glue is never going to come off ever. Superglue can be dissolved with a superglue remover but this may damage plastics so test it first on a mini you don't care about and then if it works limit exposure time as much as possible. Link to comment https://bolterandchainsword.com/topic/258349-anything-to-remove-plastic-glue/#findComment-3141865 Share on other sites More sharing options...
Marshal van Trapp Posted August 5, 2012 Share Posted August 5, 2012 unfortunately plastic glue is on a ticking clock with removal, the longer you wait the harder it is until it becomes impossible  with most plastic glues you can unbind pieces up to 36 hours after glued, but even then its going to leave pieces noticeably changed (they will look melted) if its more than a year old only a knife will re-separate them Link to comment https://bolterandchainsword.com/topic/258349-anything-to-remove-plastic-glue/#findComment-3141878 Share on other sites More sharing options...
Leonis Posted August 5, 2012 Share Posted August 5, 2012 Everyone needs a jewelers saw in their tool box anyway, right? -_- Link to comment https://bolterandchainsword.com/topic/258349-anything-to-remove-plastic-glue/#findComment-3141883 Share on other sites More sharing options...
madscuzzy Posted August 6, 2012 Share Posted August 6, 2012 Actually you can remove, provided the seal or weld hasn't perfectly formed, which is most cases... try using thin plastic glue. This will seep into whatever cracks there are and will help loosen/soften the bond. It isn't fullproof, but does work. Do give it a try. Link to comment https://bolterandchainsword.com/topic/258349-anything-to-remove-plastic-glue/#findComment-3142096 Share on other sites More sharing options...
Valkyrion Posted August 6, 2012 Author Share Posted August 6, 2012 Cheers, so it looks like hacking their arms, filing down the melt and seeing what damage is done...smashing. Link to comment https://bolterandchainsword.com/topic/258349-anything-to-remove-plastic-glue/#findComment-3142312 Share on other sites More sharing options...
