Were to Buy frost axes ...
TrentL
I think a better question is "How should I model Frost axes". Based on the codex description there are generally two ways you can start.
An axe with chain teeth, or an axe with a crystallized/mirror finish. My Frost "stuff" is typically chain teeth... specifically chain teeth that looks like bone as they are made with or designed around Fenrisian Kraken materials.
an interesting way would be to use plasticard.
if you take a long thin strip and cut out random jagged "teeth" you could then arrange them in between 2 axe shaped pieces of thinner plasticard as the cutting edge and then glue the other end to the top of a suitable handle (a TH with the head taken off or perhaps a banner pole?)
