power axes
if you are looking to convert some then assault terminator thunder hammers make a good base. remove the front and back parts of the hamer but leave the power gubbins and replace with a bit of plasticard in your chosen shape.
you may also want to replace the hand hold the axe/hammer as its scaled for a terminator so a bit big for a marine if you keep the whole gauntlet
https://bolterandchainsword.com/topic/258841-power-axes/#findComment-3147758
Axes are very lacking. There is just the one assault squad axe, and the Wolves and BT axe are very chapter specific with the wolf head or the axe being chained to the hand. There are some other bigger axes like glaives or TW bits, but they don't really work for what I need.
I found the Fantasy range had Chaos warrior axes that look like what I wanted. Only problem is they are not in a power armor hand so you need to snip off the axe and reattach to an astartes hand.
these are them:
http://www.ebay.com/itm/Chaos-Warrior-L-Ax...#ht_1633wt_1397
https://bolterandchainsword.com/topic/258841-power-axes/#findComment-3147835
As Tennis Ball and Red Fury suggested, you can find some very nice and characterful axes in the fantasy range (either Bitz or a unit-box, the latter of which would also supply a good few spare parts for other kit-bashes. Severed heads at the least).
https://bolterandchainsword.com/topic/258841-power-axes/#findComment-3148428
