SgtTelion Posted August 15, 2012 Share Posted August 15, 2012 Hi guys, Probably a simple question but... Where does it say I can snap fire with a Boltgun (or not as the case may be). The small paragraph in the rule book doesnt really tell you much. Cheers in advance! Link to comment Share on other sites More sharing options...
Seahawk Posted August 15, 2012 Share Posted August 15, 2012 You only need to take Snap Shots when you are forced to do so. It will tell you when this is the case. Link to comment Share on other sites More sharing options...
dswanick Posted August 15, 2012 Share Posted August 15, 2012 The Snap Shots rule is on Pg.31 of the BRB. Link to comment Share on other sites More sharing options...
SgtTelion Posted August 16, 2012 Author Share Posted August 16, 2012 Cheers for the replies. I have read the rule, but it's not exactly comprehensive. Also, it usually says something along the lines of "may snap fire if able to do so". How do I know what weapons can and can't snap fire? Is it just heavy weapons? This is what I am reading from the rules. Link to comment Share on other sites More sharing options...
Grey Mage Posted August 16, 2012 Share Posted August 16, 2012 Anything that isnt a blast or template weapon can snap fire- as those are the only weapons that are stated to be unable to do so. Link to comment Share on other sites More sharing options...
Kastor Krieg Posted August 16, 2012 Share Posted August 16, 2012 And there is a case when a template weapon (i.e. any flamer) can fire when others are forced to "snap fire", that is fire in overwatch. Look for the Wall of Death rule - D3 autohits with the strength of the flamer. Link to comment Share on other sites More sharing options...
Seahawk Posted August 16, 2012 Share Posted August 16, 2012 The Snap Shots rule just describes how to do it, and it can be done with any and all weapons, unless they have a restriction. Blast and Template weapons, for instance. The situation will tell you when you are forced to, such as being Pinned or Fleeing. Really, I'd suggest hitting the BRB again. Every question is easily answered if you just give it a read (see my sig). ;) Link to comment Share on other sites More sharing options...
