Lord Morgrim Posted August 15, 2012 Share Posted August 15, 2012 Apart from cost and modelling reasons, what is the advantage of taking a power axe over a Power fist?.....both strike at initiative......trying to decide whether the axe is worth it on my Chaos Terminators... Link to comment https://bolterandchainsword.com/topic/259039-power-fists-vs-power-axes/ Share on other sites More sharing options...
greatcrusade08 Posted August 15, 2012 Share Posted August 15, 2012 Apart from cost and modelling reasons, what is the advantage of taking a power axe over a Power fist?.....both strike at initiative......trying to decide whether the axe is worth it on my Chaos Terminators... the power axe gets +1A for dual ccws, in terms of chaos terminators you dont get the pistol so a fist is probably better tbh Link to comment https://bolterandchainsword.com/topic/259039-power-fists-vs-power-axes/#findComment-3150048 Share on other sites More sharing options...
Acebaur Posted August 16, 2012 Share Posted August 16, 2012 Apart from cost and modelling reasons, what is the advantage of taking a power axe over a Power fist?.....both strike at initiative......trying to decide whether the axe is worth it on my Chaos Terminators... the power axe gets +1A for dual ccws, in terms of chaos terminators you dont get the pistol so a fist is probably better tbh On TDA, yeah might as well get the Fist as you won't benefit from the +1 attack either way. On normal troops though, the axe is superior for killing MEQ. Here is a copy of what I posted when we talked about this over in the BT forum Here is some Axe vs Fist Mathammer against MEQ On the Charge (if you take AAC) Axe - 4 attacks = 1.333 dead Fist - 3 attacks = 1.25 dead On the Charge (without AAC) Axe - 3 attacks = 1 dead Fist - 2 attacks = .8333 dead Off the Charge Axe - 2 attacks = .667 dead Fist - 1 attack = .416 dead Of course this was geared towards BT Initiates, but you can see that with more attacks the axe wins ever time. Link to comment https://bolterandchainsword.com/topic/259039-power-fists-vs-power-axes/#findComment-3150063 Share on other sites More sharing options...
MikeyB83 Posted August 16, 2012 Share Posted August 16, 2012 http://www.bolterandchainsword.com/index.p...howtopic=255911 this thread lists some pretty interesting points on power weapons in the new version of 40k. depends on what you're after too, axe is great for taking on powerful infantry (nobs, necron lords etc) and you'll at least get +1A with another ccw, whereas a fist will be better used for tank killing. on tda models, i'd say the same principle applies, just that they can walk through better even when under fire. Link to comment https://bolterandchainsword.com/topic/259039-power-fists-vs-power-axes/#findComment-3150068 Share on other sites More sharing options...
greatcrusade08 Posted August 16, 2012 Share Posted August 16, 2012 the axe can also be combined with a second ccw, for example another type of power weapon for the additional attack (for only 5 points on the fist) giving you the option to strike at initiative with the one weapon, or hit with the axe at I1 and AP2 Link to comment https://bolterandchainsword.com/topic/259039-power-fists-vs-power-axes/#findComment-3150080 Share on other sites More sharing options...
rpnightsend Posted August 16, 2012 Share Posted August 16, 2012 the axe can also be combined with a second ccw, for example another type of power weapon for the additional attack (for only 5 points on the fist) giving you the option to strike at initiative with the one weapon, or hit with the axe at I1 and AP2 That would be 30 points (assuming both cost 15 pts). Interesting Caveat is that 2 specialist weapons (Fist and claw, for example) still add +1 attack. So for 40 pts, you can have 2 weapons that are both more likely to wound, and have the same stats otherwise. If you really want the pistol (understandably), i see this being a good debate. If i didn't care about shooting, i would always go claw/fist over sword/axe. Link to comment https://bolterandchainsword.com/topic/259039-power-fists-vs-power-axes/#findComment-3150437 Share on other sites More sharing options...
greatcrusade08 Posted August 16, 2012 Share Posted August 16, 2012 good point, my SM biker captain has fist/claw and its an awesome combo (plus he still gets to shoot) Link to comment https://bolterandchainsword.com/topic/259039-power-fists-vs-power-axes/#findComment-3150663 Share on other sites More sharing options...
DarkGuard Posted August 16, 2012 Share Posted August 16, 2012 Of course, that is a lot of points for an extra attack. I'd rather just take the one I'd use most and save some points. Link to comment https://bolterandchainsword.com/topic/259039-power-fists-vs-power-axes/#findComment-3150697 Share on other sites More sharing options...
rpnightsend Posted August 16, 2012 Share Posted August 16, 2012 Of course, that is a lot of points for an extra attack. I'd rather just take the one I'd use most and save some points. Well yes, thats why I said IF you aren't taking the pistol. I'd always find 10 points for the rerolls to wound/S8 Link to comment https://bolterandchainsword.com/topic/259039-power-fists-vs-power-axes/#findComment-3150763 Share on other sites More sharing options...
*Furyou Miko Posted August 16, 2012 Share Posted August 16, 2012 Remember you have to choose between S8 and rerolling to wound, you don't get both. Link to comment https://bolterandchainsword.com/topic/259039-power-fists-vs-power-axes/#findComment-3150778 Share on other sites More sharing options...
Warsmith IV Posted August 18, 2012 Share Posted August 18, 2012 I think the clincher is how much you really need that +3 strength (for MEQ) at 10 points. If you want to kill tanks..welll actually just get a Chinafist for another 5, but for me the value of a Power Fist is a) Instant Death to MEQ :lol: Easier wounds on Monstrous Creatures 9typically T6) So I rather like them since I mostly fight Angels (both the Blood and Dark varieties) and Tyranids. Then again, for me it's always Thunder Hammers so... Link to comment https://bolterandchainsword.com/topic/259039-power-fists-vs-power-axes/#findComment-3152355 Share on other sites More sharing options...
