Myxx Posted August 22, 2012 Share Posted August 22, 2012 I must admit, I just got my 6e book and am trying to absorb it. From what I've read here on the B&C and a bit of the big book, I have a question. if SMs are my primary, and I take Draigo as my secondary HQ, do paladins count as troops? I assume yes, but one thing I've learned about GW rules, is that common sense isn't always correct... Link to comment https://bolterandchainsword.com/topic/259373-gk-as-2nd-foc/ Share on other sites More sharing options...
AnImA8 Posted August 22, 2012 Share Posted August 22, 2012 I would say yes. And I'd add that if GW meant for there to be any restrictions on the special rules that certain characters have (i.e. making Paladins Troops) then they'd have written it into the BRB where it lists the other restrictions allied detachments have. Link to comment https://bolterandchainsword.com/topic/259373-gk-as-2nd-foc/#findComment-3154916 Share on other sites More sharing options...
sirk Posted August 22, 2012 Share Posted August 22, 2012 Yes, unless a faq will come out stating differently, you can. Modifies in the composition of the list are always done to the whole army, that is composed by detachments, so all detachments in the army get the change. For example, if you play at 2000 with 2 foc, Draigo will modify both primary detachments allowing paladins as troops in both. Link to comment https://bolterandchainsword.com/topic/259373-gk-as-2nd-foc/#findComment-3155121 Share on other sites More sharing options...
Brother_Fatiswon Posted August 28, 2012 Share Posted August 28, 2012 .... so if a tree falls in the forest and hits you in the head... did it kill you? but on topic... if SM are your prime and you take Lysander as your HQ w/ bolter drill, and being an IC then you take GK and draigo as your 2nd and a 10 man Paladin squad with storm BOLTERS with psybolts (+1s) does the SC rule transfer from prime to secondary units if attached? ? ? Link to comment https://bolterandchainsword.com/topic/259373-gk-as-2nd-foc/#findComment-3159741 Share on other sites More sharing options...
Darkmagi Posted August 28, 2012 Share Posted August 28, 2012 unfortunately grey knights don't have any battle brothers... so no allied IC attaching for us. Link to comment https://bolterandchainsword.com/topic/259373-gk-as-2nd-foc/#findComment-3159745 Share on other sites More sharing options...
