Brother Captain Firelupus Posted August 23, 2012 Share Posted August 23, 2012 Hi All, I have been toying with the idea of running a Godhammer Landraider with a iron priest inside as purely a main battle tank. As i play 1250pts the 300pts is a sizable investment, but i think i need to try it out and see how much firepower it will soak up with a potential of 10 hull points. that is assuming that the iron priest needs to repair the tank every turn. Link to comment https://bolterandchainsword.com/topic/259462-landraider-and-iron-priest/ Share on other sites More sharing options...
Blackmane Posted August 24, 2012 Share Posted August 24, 2012 -and assuming it doesn't run into scourges spamming haywire blasters :D Link to comment https://bolterandchainsword.com/topic/259462-landraider-and-iron-priest/#findComment-3156614 Share on other sites More sharing options...
dswanick Posted August 24, 2012 Share Posted August 24, 2012 I have been toying with the idea of running a Godhammer Landraider Just a little quibble, but there is no "Godhammer Landraider". The standard pattern Land Raider mounts Godhammer Lascannons, but it is a Phobos pattern with no special name. http://i1127.photobucket.com/albums/l634/dswanick/Phobospattern.jpg Link to comment https://bolterandchainsword.com/topic/259462-landraider-and-iron-priest/#findComment-3156701 Share on other sites More sharing options...
Belfast Posted August 24, 2012 Share Posted August 24, 2012 Why not go iron priest with full or mostly full retinue? Not only do you improve you repair chance with the servitors but you can also get 4 cyber wolves that can do some serious damage for few points and give your land raider a lot more versatility. Link to comment https://bolterandchainsword.com/topic/259462-landraider-and-iron-priest/#findComment-3157003 Share on other sites More sharing options...
Belfast Posted August 24, 2012 Share Posted August 24, 2012 Edit: double post Link to comment https://bolterandchainsword.com/topic/259462-landraider-and-iron-priest/#findComment-3157032 Share on other sites More sharing options...
Wulfebane Posted August 24, 2012 Share Posted August 24, 2012 Probably doesn't intend to disembark him from the land raider. Link to comment https://bolterandchainsword.com/topic/259462-landraider-and-iron-priest/#findComment-3157064 Share on other sites More sharing options...
Russ Brother 92 Posted August 24, 2012 Share Posted August 24, 2012 Probably doesn't intend to disembark him from the land raider. In that case just take the three servitors with no extras and you'll be rolling equivi 3+ to repair a hull point :) (+1 for each servitor) Link to comment https://bolterandchainsword.com/topic/259462-landraider-and-iron-priest/#findComment-3157076 Share on other sites More sharing options...
