Leandred Posted August 28, 2012 Share Posted August 28, 2012 Hola, anyone here that has a saved copy of the Deamonettes painting guide from GW? Just picked up painting again and want to finish my Blood Bowl Chaos team. Was using that guide to paint my beastmen skin and horns... Have tried to search for it on the net but without any luck. Only thing i got is that GW took them down and refuse to put up them in an archive section as goodwill. Cheers Link to comment https://bolterandchainsword.com/topic/259743-gw-deamonettes-painting-guide/ Share on other sites More sharing options...
Jofus Posted August 28, 2012 Share Posted August 28, 2012 Not to sure if this is what you are looking for but this is the colors that GW says they use for the Daemonettes skin. Daemonette Hide Druchii Violet Warpfiend Grey Slaanesh Grey Praxeti White I have used this on some Dark Eldar and it comes close to GW's white Daemoneets. I would rather use a layer white over the drybush to give a better finish. If you are wanting to have grey daemoneets that GW sometimes shows just leave out the white and it comes pretty close to that too. Link to comment https://bolterandchainsword.com/topic/259743-gw-deamonettes-painting-guide/#findComment-3160214 Share on other sites More sharing options...
Leandred Posted August 29, 2012 Author Share Posted August 29, 2012 Cool, thanks alot! will look into it. Just need to convert your names to the old paint names. Cheers! Link to comment https://bolterandchainsword.com/topic/259743-gw-deamonettes-painting-guide/#findComment-3160880 Share on other sites More sharing options...
