Vesem Posted August 28, 2012 Share Posted August 28, 2012 In the BRB on page 76 it says "Calculate the assault results as normal, counting each glancing hit as 1 Wound, and each penetrating hit as 2 Wounds." In the BRB on page 429 it says "reduce the vehicles remaining Hull Points by 1 for each unsaved glancing or penetrating hit." Both of these are in regards to assaults against vehicles, which one do you use? Link to comment Share on other sites More sharing options...
LPetersson Posted August 28, 2012 Share Posted August 28, 2012 You use both as they are not mutually exclusive. Link to comment Share on other sites More sharing options...
Vesem Posted August 28, 2012 Author Share Posted August 28, 2012 Then I guess I'm even more confused then I thought, we had been using the rule on page 76 before as meaning you take two hull points off of a vehicle when it's penetrated in melee combat. Link to comment Share on other sites More sharing options...
Vesem Posted August 28, 2012 Author Share Posted August 28, 2012 Ah, reread it again. Thanks makes since now. Link to comment Share on other sites More sharing options...
DarkGuard Posted August 28, 2012 Share Posted August 28, 2012 Indeed. One is about vehicle damage. The other is about combat res. No rules conflict at all here. Link to comment Share on other sites More sharing options...
