Valkyrion Posted September 4, 2012 Share Posted September 4, 2012 I want some bear arms to fit CSM models, ideally ones that a normal sized shoulder pad can go over, so before I order the bits I'd like to know which would better fit the scale of a CSM? Anyone done this before? Any pictures or any other alternatives? I think the catachan arms are a bit small. Cheers. Link to comment https://bolterandchainsword.com/topic/260181-orks-vs-marauders/ Share on other sites More sharing options...
The Colossus Posted September 4, 2012 Share Posted September 4, 2012 I find Ork arms far to big if you want shoulderpads. Also, they're a bit too long. Link to comment https://bolterandchainsword.com/topic/260181-orks-vs-marauders/#findComment-3166064 Share on other sites More sharing options...
space wolf Posted September 4, 2012 Share Posted September 4, 2012 Catachan arms...you want Catachan arms... Link to comment https://bolterandchainsword.com/topic/260181-orks-vs-marauders/#findComment-3166191 Share on other sites More sharing options...
Razblood Posted September 4, 2012 Share Posted September 4, 2012 Lizardman Saurus Arms maybe... Link to comment https://bolterandchainsword.com/topic/260181-orks-vs-marauders/#findComment-3166201 Share on other sites More sharing options...
Captain Hwarang Posted September 4, 2012 Share Posted September 4, 2012 I think the catachan arms would be a bit small too, not to mention ugly. I think ork arms would be your best bet, although the hands are WAY too big. Also keep in mind that the shoota is attached to the arm as a single bit. But if you're chopping the hands off anyway, that shouldn't be too big of a deal. -CH Link to comment https://bolterandchainsword.com/topic/260181-orks-vs-marauders/#findComment-3166639 Share on other sites More sharing options...
JaM_TW Posted September 6, 2012 Share Posted September 6, 2012 Catachan arms fit, or the WHFB marauder arms. I think you should look into those. edit: I had minis that used both, it works. Ork arms are way too big. Link to comment https://bolterandchainsword.com/topic/260181-orks-vs-marauders/#findComment-3168290 Share on other sites More sharing options...
Blindhamster Posted September 11, 2012 Share Posted September 11, 2012 use catachan arms from either the heavy weapon sprue or the catachan command squad, they're far far far better quality and look perfect for a marine. Link to comment https://bolterandchainsword.com/topic/260181-orks-vs-marauders/#findComment-3172817 Share on other sites More sharing options...
